I’m using CentOS 5.5. My computer use 3 grapichs card. Here is the deviceQuery log:
[codebox] CUDA Device Query (Runtime API) version (CUDART static linking)
There are 3 devices supporting CUDA
Device 0: “Tesla C1060”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 4294770688 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Device 1: “Quadro FX 1700”
CUDA Capability Minor revision number: 1
Total amount of global memory: 536150016 bytes
Number of multiprocessors: 4
Number of cores: 32
Total number of registers available per block: 8192
Warp size: 32
Clock rate: 0.92 GHz
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Device 2: “Tesla C1060”
Warp size: 32
Integrated: No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4243455, CUDA Runtime Version = 3.0, NumDevs = 3, Device = Tesla C1060, Device = Quadro FX 1700
PASSED
[/codebox]
I’ve created a simple program in java that executes the marching cubes example program. My java program creates a thread for each device. Each thread executes the marching cubes program in a different device. I’ve tried the marching cubes program with each device and it works fine. But when I try to execute the marching cubes in the three device concurrently, the Quadro FX 1700 crashes because it is out of memory. If i try to execute the marching cubes on only the Quadro FX 1700 it works fine.
Can anyone explain me why this happen? There is any solution to use the three graphics card in parallel?
