problem using templates and friend functions in CUDA I can't compile templated friend functions
EDIT #2:
I have finally come up with the test case I’m actually stymied by. My original post (below) was a matter of a syntax error, but wasn’t fully reproducing the problem I’m seeing with a larger piece of code. The “solution” to my compilation problem in my original post (removing the template< typename > declaration at the top of the friend function) doesn’t work in this case.
#include <cuda.h>
#include <iostream>
template < typename T >
class xyzVec
private:
  T x_, y_, z_;
public:
  __device__
  xyzVec() : x_(T(0)), y_(T(0)), z_(T(0)) {}
  __device__
  xyzVec( T x, T y, T z ) : x_(x), y_(y), z_(z) {}
friend
  __device__
  xyzVec
  operator + ( xyzVec const & a, xyzVec const & b )
    return xyzVec( a.x_ + b.x_, a.y_ + b.y_, a.z_ + b.z_ );
__device__ T length() const { return sqrt( x_*x_ + y_*y_ + z_*z_ ); }
__device__ T dot( xyzVec const & other ) const { return x_*other.x_ + y_*other.y_ + z_*other.z_; }
friend
  __device__
  T cos_of( xyzVec const & a, xyzVec const & b ) {
    T const mag = a.length() * b.length();
    if ( mag > T( 0 )) {
      return  a.dot( b ) / mag;
    } else {
      return T( 1 );
//template< typename T >
//__device__
//xyzVec< T >
//operator + ( xyzVec<T> const & a, xyzVec<T> const & b );
__device__
T cos_of( xyzVec<T> const & a, xyzVec<T> const & b );
template< class T >
__global__
void
device_add( T * d_dest, T * d_src1, T * d_src2, unsigned int n ) {
  unsigned int index = threadIdx.x + blockIdx.x * blockDim.x;
  if ( index <= n ) {
    xyzVec< T > a(1,2,3);
    xyzVec< T > b(2,3,4);
    xyzVec< T > c( a+b );
    d_dest[ index ] = d_src1[ index ] + d_src2[ index ] + cos_of( a, b );
void
add_vectors_on_device(
  float * h_dest,
  float * h_src1,
  float * h_src2,
  unsigned int n
  std::cout << "arrived in add_vectors_on_device" << std::endl;
float * d_dest, * d_src1, * d_src2;
  int err1 = cudaMalloc( & d_dest, sizeof( float ) * n );
  int err2 = cudaMalloc( & d_src1, sizeof( float ) * n );
  int err3 = cudaMalloc( & d_src2, sizeof( float ) * n );
if ( err1 != 0 ) { std::cerr << "Could not allocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_dest.  Err: " << err1 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
  if ( err2 != 0 ) { std::cerr << "Could not allocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_src1.  Err: " << err2 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
  if ( err3 != 0 ) { std::cerr << "Could not allocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_src2.  Err: " << err3 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
cudaMemcpy( d_src1, h_src1, sizeof( float ) * n, cudaMemcpyHostToDevice );
  cudaMemcpy( d_src2, h_src2, sizeof( float ) * n, cudaMemcpyHostToDevice );
unsigned int n_blocks = ( n + 255 ) / 256;
  device_add<<< n_blocks, 256 >>>( d_dest, d_src1, d_src2, n );
cudaMemcpy( h_dest, d_dest, sizeof( float ) * n, cudaMemcpyDeviceToHost );
  int err4 = cudaFree( d_dest ); d_dest = 0;
  int err5 = cudaFree( d_src1 ); d_src1 = 0;
  int err6 = cudaFree( d_src2 ); d_src2 = 0;
  if ( err4 != 0 ) { std::cerr << "Could not deallocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_dest.  Err: " << err4 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
  if ( err5 != 0 ) { std::cerr << "Could not deallocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_src1.  Err: " << err5 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
  if ( err6 != 0 ) { std::cerr << "Could not deallocate block of size " << sizeof( float ) * n << " bytes on device when allocating space for d_src2.  Err: " << err6 << " from " << __FILE__ << " " << __LINE__ << std::endl; exit(1); }
int
main()
bool error( false );
  unsigned int num_floats = 1000;
  float * h_dest; float * h_src1; float * h_src2;
  h_dest = (float*) malloc( sizeof( float ) * num_floats );
  h_src1 = (float*) malloc( sizeof( float ) * num_floats );
  h_src2 = (float*) malloc( sizeof( float ) * num_floats );
  for ( int ii = 0; ii < num_floats; ++ii ) {
    h_src1[ ii ] = ii;
    h_src2[ ii ] = num_floats - ii;
  add_vectors_on_device( h_dest, h_src1, h_src2, num_floats );
    if( std::abs( h_dest[ ii ] - num_floats) > 1e-5 ) {
      std::cout << "Error with position " << ii << " in add_vectors_on_device: " << std::abs( h_dest[ ii ] - (num_floats)) << std::endl;
      error = true;
  free( (void*) h_dest );
  free( (void*) h_src1 );
  free( (void*) h_src2 );
  if ( ! error ) {
    std::cout << "SUCCESS" << std::endl;
which produces this error:
w$ nvcc -o test  -I/usr/local/cuda/include -lcuda main.cu
main.cu(30): error: calling a __device__ function("length") from a __host__ function("cos_of") is not allowed
main.cu(32): error: calling a __device__ function("dot") from a __host__ function("cos_of") is not allowed
3 errors detected in the compilation of "/tmp/tmpxft_00003cd8_00000000-9_main.cpp4.ii".
but if I put in the “template< typename >” preface to the function,
  friend
  __device__
    } else {
      return T( 1 );
I get this error:
./main.cu(61): Error: External calls are not supported (found non-inlined call to _Z6cos_ofIfET_RK6xyzVecIS0_ES4_)
If I comment out the “external” declaration of this function, I get this error:
main.cu(61): error: no instance of "cos_of" matches the argument list
            argument types are: (xyzVec<float>, xyzVec<float>)
          detected during instantiation of "void device_add(T *, T *, T *, unsigned int) [with T=float]"
(88): here
1 error detected in the compilation of "/tmp/tmpxft_00003d61_00000000-4_main.cpp1.ii".
I’m not sure why “operator +” and “cos_of” should have a different syntax, but I can work around that. What’s got me most puzzled is that I cannot seem to get this “cos_of” function implemented at all.
Any help would be appreciated.
ORIGINAL POST BELOW
I have boiled my problem down to a pretty small test case. I want to define a friend function for a templated class and have this friend function run on the device. I can’t get past the compiler errors, though I’ve tried very many things.
Here is my example code:
#include <cuda.h>
#include <iostream>
class xyzVec
private:
  T x_, y_, z_;
public:
  __device__ xyzVec() : x_(T(0)), y_(T(0)), z_(T(0)) {}
  __device__ xyzVec( T x, T y, T z ) : x_(x), y_(y), z_(z) {}
  friend
  __device__
  xyzVec
  operator + ( xyzVec const & a, xyzVec const & b ) {
__device__
xyzVec<T>
template< class T >
__global__
void
  if ( index <= n ) {
    //xyzVec< T > a(1,2,3);
    //xyzVec< T > b(2,3,4);
    //xyzVec< T > c( a+b );
    d_dest[ index ] = d_src1[ index ] + d_src2[ index ];// + cos_of( a, b );
void
  float * h_dest,
  float * h_src1,
  float * h_src2,
  unsigned int n
int
main()
    h_src1[ ii ] = ii;
      error = true;
  if ( ! error ) {
which I can compile with:
and it compiles and runs. But if I uncomment the use of the xyzVec class in “device_add”, I am unable to work past the compilation problems. That is, if I change device_add as follows:
template< class T >
__global__
void
  if ( index <= n ) {
I get this error messages:
./main.cu(38): Error: External calls are not supported (found non-inlined call to _ZplIfE6xyzVecIT_ERKS2_S4_)
If I comment out the outside-of-the-class declaration of operator + (lines 25–28), I get this error message:
main.cu(38): error: no operator "+" matches these operands
            operand types are: xyzVec<float> + xyzVec<float>
(66): here
1 error detected in the compilation of "/tmp/tmpxft_00003bc0_00000000-4_main.cpp1.ii".
If I move the function body outside of the class, and simply forward-declare “operator +” (replacing the old class declaration and the function declaration) as shown in the code below,
class xyzVec
private:
  T x_, y_, z_;
public:
  __device__
  __device__
  friend
  __device__
  xyzVec
  operator + ( xyzVec const & a, xyzVec const & b );
__device__
xyzVec< T >
  return xyzVec< T >( a.x_ + b.x_, a.y_ + b.y_, a.z_ + b.z_ );
then I get this error message:
main.cu(28): error: member "xyzVec<T>:<img src='http://forums.nvidia.com/public/style_emoticons/<#EMO_DIR#>/bloated.gif' class='bbc_emoticon' alt=':X' />_ [with T=float]"
(8): here is inaccessible
          detected during:
            instantiation of "xyzVec<T> operator+(const xyzVec<T> &, const xyzVec<T> &) [with T=float]"
(40): here
(68): here
          detected during:
(40): here
(68): here
main.cu(28): error: member "xyzVec<T>::y_ [with T=float]"
          detected during:
(40): here
(68): here
          detected during:
(40): here
(68): here
main.cu(28): error: member "xyzVec<T>::z_ [with T=float]"
          detected during:
(40): here
(68): here
          detected during:
(40): here
(68): here
6 errors detected in the compilation of "/tmp/tmpxft_00003bd3_00000000-4_main.cpp1.ii".
… and at this point, I have exhausted all permutations of this code that I can think of.
EDIT:
It seems like one more permutation and it works:
class xyzVec
private:
  T x_, y_, z_;
public:
  __device__
  __device__
friend
  __device__
  xyzVec
//__device__
//xyzVec< T >
I thought I had tried this, so, I’m a little puzzled at the moment. Sorry for the confusion.
