Problem using tex3D(...) problem at compilation time
hi everybody,
I am having a strange compilation error :
1>### Assertion failure at line 123 of …/…/be/cg/NVISA/expand.cxx:
1>### Compiler Error in file C:\Users\YBENAA~1\AppData\Local\Temp/tmpxft_00001608_00000000-9_Cuda.cpp3.i during Code_Expansion phase:
1>### unexpected mtype
1>nvopencc ERROR: C:\CUDA\bin/…/open64/lib//be.exe returned non-zero status 1
when using the fucntion text3D(tex,0,0,0); (tex is initialized and filled correcty)
this is the code source :
		int pipi = _pipi;
		ray_position[0]*=Interpolation;
		ray_position[1]*=Interpolation;
		ray_position[2]*=Interpolation;
		ray_increment[0]*=Interpolation;
		ray_increment[1]*=Interpolation;
		ray_increment[2]*=Interpolation;
		for(; kk <= nbr_loops; ) // pour chaque slice à partir du premier (le plus proche)
			I = (int)(ray_position[0]);
			J = (int)(ray_position[1]);
			K = (int)(ray_position[2]);
			valeur16 = tex3D(tex, 0, 0,0);
			if(VP_ISMASK_TEMP(valeur16))
				ok = (_Mask & VP_SEGMENTATION_MASK_TEMP);
			else
				MASK = VP_GETMASK(valeur16);
				switch(MASK)
				case VP_MASK_VISIBLE:
					ok = (_Mask & VP_SEGMENTATION_MASK_VISIBLE);
					break;
				case VP_MASK_TABLE:
					ok = (_Mask & VP_SEGMENTATION_MASK_TABLE);
					break;
				case VP_MASK_VASCULAR:
					ok = (_Mask & VP_SEGMENTATION_MASK_VASCULAR);
					break;
				case VP_MASK_OS:
					ok = (_Mask & VP_SEGMENTATION_MASK_OS);
					break;
				case VP_MASK_CALCIFICATION:
					ok = (_Mask & VP_SEGMENTATION_MASK_CALCIFICATIONS);
					break;
				case VP_MASK_INVISIBLE:
					ok = (_Mask & VP_SEGMENTATION_MASK_INVISIBLE);
					break;
				default:
					ok = FALSE;
					break;
did some one have and idea why this hapens ?
think you
It’s hard to say without seeing the full code, but the compiler should never crash like this. Please file a bug.
