Hello!
I’m trying to use two different cameras on a python project, using CV2. One is an ‘onboard’ camera, with IMX219 chip. The other is a USB thermal camera. When I use each of them separately, they work fine. But when I try to open the CSI Camera with the USB camera plugged, It doesn’t work. When I try this:
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=320, height=240, format=(string)NV12, framerate=(fraction)20/1' ! nvoverlaysink -e
It says something like:
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
The curious thing is that sometimes it works, and I can run the two cameras together… but only sometimes. I’ve tried to find information about the parameters of this command. How can I specify a particular camera if there is more than one?
Thanks in advance for any light you can offer to me.
