i want to bind a 3D CUarray (a 3D texture of half precision floats) to a surface reference, to set its values. There’s a dedicated kernel for this. But as soon as i declare the surface reference in the kernel, the JIT compiler aborts compiling the PTX file with error message
ptxas application ptx input, line 65; fatal : Parsing error near '.surf': syntax error
This is the relevant parts from the kernel (other stuff stripped)
#include <cuda.h>
surface<void, 3> volume_surface_reference;
__global__ void loader(int param, int *ptr) {
// surf3Dwrite(0, volume_surface_reference, 2, 1, 1, cudaBoundaryModeTrap);
and this from the PTX (error caused by last line)
.entry _Z6loaderiPi (
.param .s32 __cudaparm__Z6loaderiPi_param,
.param .u64 __cudaparm__Z6loaderiPi_ptr)
.reg .u32 %r<4>;
.reg .u64 %rd<3>;
.loc 14 19 0
$LDWbegin__Z6loaderiPi:
.loc 14 27 0
ld.param.s32 %r1, [__cudaparm__Z6loaderiPi_param];
add.s32 %r2, %r1, 1;
ld.param.u64 %rd1, [__cudaparm__Z6loaderiPi_ptr];
st.global.s32 [%rd1+0], %r2;
.loc 14 28 0
exit;
$LDWend__Z6loaderiPi:
} // _Z6loaderiPi
.surf .u64 volume_surface_reference;
Also, if i additionally try to compile with surf3Dwrite() uncommented, nvcc aborts with
Error: External calls are not supported (found non-inlined call to __surf3Dwriteu1)
I’m using the driver API version 4.2 and a GTX 570 with capability 2.0. The 3D CUarray will also be used by another kernel by texture reference and it is defined like this
CUDA_ARRAY3D_DESCRIPTOR array3d_desc;
array3d_desc.Format = CU_AD_FORMAT_HALF;
array3d_desc.NumChannels = 1;
array3d_desc.Width = mVolume->getExtent().x;
array3d_desc.Height = mVolume->getExtent().y;
array3d_desc.Depth = mVolume->getExtent().z;
array3d_desc.Flags = CUDA_ARRAY3D_SURFACE_LDST;
if (!Cutil::safeSyncCall(cuArray3DCreate(&volume_array, &array3d_desc))) {
return false;
if (!Cutil::safeSyncCall(cuModuleGetTexRef(&volume_texture_reference, dvrModule, "volume_texture_reference"))) {
return false;
// Disabled, because not working by now.
//if (!Cutil::safeSyncCall(cuModuleGetSurfRef(&volume_surface_reference, loaderModule, "volume_surface_reference"))) {
// return false;
Cutil::safeSyncCall(cuTexRefSetFilterMode(volume_texture_reference, CU_TR_FILTER_MODE_LINEAR));
Cutil::safeSyncCall(cuTexRefSetAddressMode(volume_texture_reference, 0, CU_TR_ADDRESS_MODE_CLAMP));
Cutil::safeSyncCall(cuTexRefSetAddressMode(volume_texture_reference, 1, CU_TR_ADDRESS_MODE_CLAMP));
Cutil::safeSyncCall(cuTexRefSetAddressMode(volume_texture_reference, 2, CU_TR_ADDRESS_MODE_CLAMP));
Cutil::safeSyncCall(cuTexRefSetFlags(volume_texture_reference, 0));
Cutil::safeSyncCall(cuTexRefSetFormat(volume_texture_reference, CU_AD_FORMAT_HALF, 1));
if (!Cutil::safeSyncCall(cuTexRefSetArray(volume_texture_reference, volume_array, CU_TRSA_OVERRIDE_FORMAT))) {
return false;
//if (!Cutil::safeSyncCall(cuSurfRefSetArray(volume_surface_reference, volume_array, 0))) {
// return false;
Any ideas?
Cheers, Oliver
