Problem when move to 22.2 from 22.1 in OmniIsaacgymenv
When I find object dof, but I can’t run.
[omni.physx.tensors.plugin] Incompatible device of root transform tensor in function setRootTransforms: expected device -1, received device 0
Hi there, this error generally means that the simulation is running on the CPU so it’s expecting data on the CPU (or device -1), but the data that was passed into the setRootTransforms API was on the GPU.
