Problem when starting the docker
Hi, I am new to Clara and docker. I followed the Clara Train examples and I have successfully finished running ./installDocker.sh
Then when I run ./startDocker.sh I got the following error:
starting docker for nvcr.io/ea-nvidia-clara-train/clara-train-sdk:v4.0-EA2 using GPUS all jnotebookPort 8890 and AIAA port 5000
starting please run ./installDashBoardInDocker.sh to install the lab extensions then start the jupeter lab
once completed use web browser with token given yourip:8890 to access it
Unable to find image ‘nvcr.io/ea-nvidia-clara-train/clara-train-sdk:v4.0-EA2’ locally
docker: Error response from daemon: unauthorized: authentication required.
See ‘docker run --help’.
– exited from docker image
Can anyone let me know how to solve this? Thanks.
Hi
Thanks for you interest in clara train SDK.
Please note there is
The V4 is in EA now and requires you to register with our early access program. you then would need to log into this group and pull the container. it would be easier to do the login then a pull the docker image to narrow down what is going wrong
Hope that helps
