Problem when using CUDA 2.1 on Win XP 64 bit. nvcc cannot find a supported cl version. Only MSVC 8.0
I’m using CUDA 2.1 on Win XP 64bit. This is my first usage of CUDA.
Microsoft Visual Studio 2008 was used and it contains MSVC 9.0.
I use following command (nvcc_2.1.pdf, p20) to compile the sample project in its directory(For example D:\CUDA\projects\alignedTypes).
nvcc -cuda alignedTypes.cu --compiler-bindir=C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin -keep -dryrun
Problem:
nvcc cannot find a supported cl version. Only MSVC 8.0 and MSVC 9.0 are supported
The following has done:
Checking install following methods in CUDA_Getting_Started_2.1_Windows.pdf and verify the correct installation. I can execute *.exe file correctly.
Check the introduction of CUDA and found Microsoft Visual Studio 2008 was supported.
Anther command was tried"nvcc -cuda alignedTypes.cu --compiler-bindir=C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin\amd64\cl.exe -keep -dryrun"
but all above are still not work. I have used google to get the same problem from forum and have not find a good solution.
Can anybody tell me how to solve this?
Many thanks
