**• Hardware Platform (Jetson / GPU) GPU
**• DeepStream Version 6.2
**• TensorRT Version 8.6.0.12-1
**• NVIDIA GPU Driver Version (valid for GPU only) 525.105.17
**• Issue Type( questions, new requirements, bugs) bug
Hello!
I’m trying to connect tracking with re-identification to my application. In this case DeepSort. deepstream_preprocess_test.py used as a base. Config config_tracker_NvDeepSORT.yml is unchanged. At startup, the following message appears and re-identification does not work.
If I connect DeepSort tracking through the deepstream-app application. The same.
resnet34_peoplenet_pruned_int8 used as PGIE
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Loading TRT Engine for tracker ReID…
[NvMultiObjectTracker] Loading Complete!
ERROR: [TRT]: 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
