Hello, I’m new to CUDA so please be patient… :)
I’m trying to programe a device function that solves a cubic function, but I’m getting “Invalid operation” error.
The device code is the following:
[codebox]/*c[0] + c[1]*x + c[2]*x^2 + c[3]x^3 = 0/
device
int SolveCubic2(float c[ 4 ], float s[ 3 ])
int i, num;
float sub, a, b, cc, sq_a, sqrt_d, p, q, cb_p, d, u, v, phi, t,
onethird;
/* normal form: x^3 + ax^2 + bx + c = 0 */
a = c[2] / c[3];
b = c[1] / c[3];
cc = c[0] / c[3];
/* substitute x = y-A/3 to eliminate quadric term: x^3 + px + q = 0 */
sq_a = a * a;
p = 1.0 / 3.0 * (-1.0 / 3.0 * sq_a + B );
q = 0.5 * (2.0/27.0 * a * sq_a - 1.0 / 3.0 * a * b + cc );
/* use Cardano’s formula */
cb_p = p * p * p;
d = q * q + cb_p;
onethird = 1.0/3.0;
if ( isZero(d) ) {
if ( isZero(q) ) { /* one triple solution */
s[0] = 0.0;
num = 1;
else { /* one single and one double solution */
u = pow(-q,onethird);
s[0] = 2 * u;
s[1] = -u;
num = 2;
else if ( d < 0 ) { /* Casus irreducibilis: three real solutions */
phi = 1.0 / 3.0 * acos(-q / sqrt(-cb_p));
t = 2 * sqrt(-p);
s[0] = t * cos(phi);
s[1] = -t * cos(phi + M_PI / 3.0);
s[2] = -t * cos(phi - M_PI / 3.0);
num = 3;
else { /* one real solution */
sqrt_d = sqrt(d);
u = pow(sqrt_d - q,onethird);
v = - pow(sqrt_d + q,onethird);
s[0] = u + v;
num = 1;
/* resubstitute */
sub = 1.0/3.0 * a;
for ( i=0; i<num; i++) s[i] -= sub;
return num;
}[/codebox]
I’m using windows vista with sdk 2.0 on a 8800 GTX. I can’t use sqrt and power functions? What’s wrong with this code?
Thanks for the help!
