Hi :
I have installed matlab and also cuda Matlab plugin, when I run the example of the manual I get this result
#include "mex.h"
#include "cublas.h"
/* sgemm_cu.cu - Gateway function for subroutine sgemm
C = sgemm_cu(transa,transb,single(alpha),single(beta),single(A),single(B),single(C))
transa,transb = 0/1 for no transpose/transpose of A,B
Input arrays must be single precision.
void mexFunction( int nlhs, mxArray *plhs[],
int nrhs, const mxArray *prhs[])
cublasStatus status;
int M,K,L,N,MM,NN,KK;
int Mc,Kc,Lc,Nc,MMc,NNc,KKc;
int dims0[2];
int ta,tb;
float alpha,beta;
float *a,*b,*c,*cc;
float *ga,*gb,*gc;
char transa,transb;
cublasStatus retStatus;
if (nrhs != 7) {
mexErrMsgTxt("sgemm requires 7 input arguments");
} else if (nlhs != 1) {
mexErrMsgTxt("sgemm requires 1 output argument");
if ( !mxIsSingle(prhs[4]) ||
!mxIsSingle(prhs[5]) ||
!mxIsSingle(prhs[6])) {
mexErrMsgTxt("Input arrays must be single precision.");
ta = (int) mxGetScalar(prhs[0]);
tb = (int) mxGetScalar(prhs[1]);
alpha = (float) mxGetScalar(prhs[2]);
beta = (float) mxGetScalar(prhs[3]);
M = mxGetM(prhs[4]); /* gets number of rows of A */
K = mxGetN(prhs[4]); /* gets number of columns of A */
L = mxGetM(prhs[5]); /* gets number of rows of B */
N = mxGetN(prhs[5]); /* gets number of columns of B */
if (ta == 0) {
transa='n';
MM=M;
KK=K;
} else {
transa='t';
MM=K;
KK=M;
if (tb == 0) {
transb='n';
NN=N;
} else {
transb='t';
NN=L;
/* printf("transa=%c\n",transa);
printf("transb=%c\n",transb);
printf("alpha=%f\n",alpha);
printf("beta=%f\n",beta); */
/* Left hand side matrix set up */
dims0[0]=MM;
dims0[1]=NN;
plhs[0] = mxCreateNumericArray(2,dims0,mxSINGLE_CLASS,mxREAL);
cc = (float*) mxGetData(plhs[0]);
/* Three single-precision arrays */
a = (float*) mxGetData(prhs[4]);
b = (float*) mxGetData(prhs[5]);
c = (float*) mxGetData(prhs[6]);
/* STARTUP CUBLAS */
retStatus = cublasInit();
// test for error
retStatus = cublasGetError ();
if (retStatus != CUBLAS_STATUS_SUCCESS) {
printf("CUBLAS: an error occurred in cublasInit\n");
Mc=M+32-M%32;
Kc=K+32-K%32;
/* ALLOCATE SPACE ON THE GPU AND COPY a INTO IT */
cublasAlloc (Mc*Kc, sizeof(float), (void**)&ga);
// test for error
printf("CUBLAS: an error occurred in cublasAlloc\n");
cudaMemset(ga,0,Mc*Kc*4); /* zeros the array ga byte-by-byte */
retStatus = cublasSetMatrix (M, K, sizeof(float),
a, M, (void*)ga, Mc);
Lc=L+32-L%32;
Nc=N+32-N%32;
/* SAME FOR B, C */
cublasAlloc (Lc*Nc, sizeof(float), (void**)&gb);
cudaMemset(gb,0,Lc*Nc*4);
retStatus = cublasSetMatrix (L, N, sizeof(float),
b, L, (void*)gb, Lc);
MMc=MM+32-MM%32;
NNc=NN+32-NN%32;
KKc=KK+32-KK%32;
cublasAlloc (MMc*NNc, sizeof(float), (void**)&gc);
if (beta != 0.0 ) {
cudaMemset(gc,0,MMc*NNc*4);
retStatus = cublasSetMatrix (MM, NN, sizeof(float),
c, MM, (void*)gc, MMc);
/* PADDED ARRAYS */
/* printf("Op(A) has No. rows = %i\n",MMc);
printf("Op(B) has No. cols = %i\n",NNc);
printf("Op(A) has No. cols = %i\n",KKc);
printf("A has leading dimension = %i\n",Mc);
printf("B has leading dimension = %i\n",Lc);
printf("C has leading dimension = %i\n",MMc); */
/* READY TO CALL SGEMM */
(void) cublasSgemm (transa, transb, MMc, NNc, KKc, alpha,
ga, Mc, gb, Lc, beta, gc, MMc);
status = cublasGetError();
if (status != CUBLAS_STATUS_SUCCESS) {
fprintf (stderr, "!!!! kernel execution error.\n");
/* NOW COPY THE RESULTING gc ON THE GPU TO THE LOCAL c */
retStatus = cublasGetMatrix (MM, NN, sizeof(float), gc, MMc, cc, MM);
printf("CUBLAS: an error occurred in cublasGetMatrix\n");
/* FREE UP GPU MEMORY AND SHUTDOWN (OPTIONAL?) */
cublasFree (ga);
cublasFree (gb);
cublasFree (gc);
cublasShutdown();
and
A=[1.5 2 3;4 4 4];
B=[44 55 66;11 11 11]';
% Let's use some large arrays...
A=randn(4000,2000);
B=randn(2000,4000);
[m n]=size(A);
[mm nn]=size(B);
C=randn(m,nn);
alpha=-1;
beta=0;
disp('Matlab:')
tic
C1d=alpha*A*B + beta*C;
toc
% In single precision, Matlab is twice as fast! (go figure...)
tic
A1=single(A);
B1=single(B);
C1=single(C);
C1s=alpha*A1*B1 + beta*C1;
toc
% The call here is testing out the transposes of the code.
disp('CUDA:')
tic
C2=sgemm_cu(0,1,single(alpha),single(beta),single(A),single(B'),single(C));
toc
% Compare the CUDA results with the Matlab results
min(min(C2-C1s))/min(min(C1s))
max(max(C2-C1s))/max(max(C1s))
and this is a error
??? Undefined function or method 'sgemm_cu' for input arguments of type
'single'.
Error in ==> sgemm_ at 25
