Hello. I have a robot and its chassis looks like car chassis (Fig. 1).
Fig. 1
I have assembled the steering and I have two prismatic joint (left_servo_joint and right_servo_joint) for chassis steering. The coordinate frames of each prismatic joint are directed the same way (Fig. 2 and Fig. 3).
Fig.2
Fig.3
In the test model, I use a simple OmniGraph to set the positions of both joints equal to 0.025 (see Fig. 4).
Fig. 4
From start to start the directions of wheel rotation difference. Sometimes it looks like this (see Fig. 5).
Fig. 5
And sometimes everything works fine. At the same time, if the target positions of the joints are set not through the Articulation Controller (as I do), but with GUI (Property→Drive→Target Position), then the wheels always turn correctly (see Fig. 6).
Fig. 6
Do you have any idea why this is happened?
