Problem with black stripe on bottom of the image
I’m trying to process image (1920x1080, BGR) on CUDA using OpenCV object, but every time some space on bottom are black or unprocessed. It is always 1/16 of image height. I’m using the code below with some variations:
__device__ uchar3 invertColor(uchar3 color) {
	return make_uchar3(255U - color.x, 255U - color.y, 255U - color.z);
__global__ void processKernel(const uchar3 *input, uchar3 *output, int width, int height) {
	int x = blockIdx.x * blockDim.x + threadIdx.x;
	int y = blockIdx.y * blockDim.y + threadIdx.y;
	if(x < width && y < height) {
		int idx = y * width + x;
		// USER CODE BEGIN
		output[idx] = invertColor(input[idx]);
		// USER CODE END
void processImageWithCuda(const cv::cuda::GpuMat &src, cv::cuda::GpuMat &dst) {
	int width = src.cols;
	int height = src.rows;
	dim3 blockSize(16, 16);
	dim3 gridSize((width + blockSize.x - 1) / blockSize.x,
				  (height + blockSize.y - 1) / blockSize.y);
	if(&src == &dst) {
		cv::cuda::GpuMat result(src.size(), src.type());
		processKernel<<<gridSize, blockSize>>>(src.ptr<uchar3>(),
											   result.ptr<uchar3>(), width, height);
		cudaDeviceSynchronize();
		dst = std::move(result);
	} else {
		processKernel<<<gridSize, blockSize>>>(src.ptr<uchar3>(), dst.ptr<uchar3>(),
											   width, height);
I was trying to change the order of data processed by each block, but it is always invalid the bottom part of the image, not the last blocks.
Thanks for your help in advance
More or less important info
  • Host: Nvidia Xavier NX
  • System: JetPack 5.1.2
  • CUDA version: 11.4
  • OpenCV version: 4.7
  • C++ Compiler: GNU 9.4.0
  • Build method: CMake 3.16
generally speaking (or by default), a cv gpuMat will use a pitched allocation. In that case, your kernel code indexing is incorrect. This is a common issue that people run into with OpenCV and their implementation of gpuMat usage with “custom CUDA kernels”.
You can find many forum posts about it on the internet. To address this, you’ll need to extract the pitch value (I think openCV may call it step or something like that) from your gpuMat and pass it to the kernel as an argument. in your kernel code, you would replace your indexing calculation with a pitched index calculation.
As an alternative, OpenCV offers an “iterator” that will allow you to access pixels in your image in an (x,y) fashion, and it handles the step/pitch calculation.
This appears to be instructive for your case.
