Problem with bootstrap.sh [ coredns pods are not running yet... ]
Hi there,
I’m having errors while deploying Clara via the bootstrap.sh version: 0.5.0-2004.7
Server specs: Ubuntu 18.04.4 LTS
the bootstrap script installs Kubernetes successfully but then it keeps saying something about coredns
ERROR:
[INFO]: coredns pods are not running yet …
so on…
coredns suggests that there may be an issue with the networking configuration, such as issues with firewall or DNS configuration. It would be helpful in seeing logs in the coredns containers. Try the following command:
docker container ls | grep coredns
You will get a list of coredns containers running. From here, using the first string (container ID), you can execute the following command:
docker logs < containerID >
Does that log command reveal any clues into why it is not starting?
