for some of my kernels I need an atomic add of doubles, which I built myself using atom_cmpxchg from the cl_khr_int64_base_atomics extension. Somewhat to my surprise I discovered that the NVidia drivers will happily let me use the cl_khr_int64_base_atomics extension (and at least atom_cmpxchg seems to work as expected), but won’t report it in the list of supported extensions queried by specifying CL_DEVICE_EXTENSIONS to clGetDeviceInfo. This happens with both a GTX470 and a Tesla C2050 using the CUDA 3.2.1 / 260.19.12 drivers on Linux 64 Bit, and with a GTX570 using CUDA 4.0.1 / 270.61 on Windows 7.
So - is the cl_khr_int64_base_atomics extension supported or not ? If not, why does the NVidia OpenCL compiler let me use it ? And if it is, why doesn’t clGetDeviceInfo report it as supported ?
