Problem with compiling own CUDA C Code
Hello to everyone,
i am trying to compile my own program written in CUDA C.
On my computer i run win7 x64 with a GTX 260.
Therefore i installed CUDA SDK, latest driver, CUDA toolkit and Visual Studio 2010
driver: 296.10-desktop-win7-winvista-64bit-international-whql
sdk: gpucomputingsdk_4.1.28_win_64
toolkit: cudatoolkit_4.1.28_win_64
Ok, so far so good …
After installing everything i started the precompiled examples from the sdk, those run perfect.
Then i compiled the example “bandwidthTest” from the CUDA sdk, perfect, too. Found the new binary unter …/bin/Win64/Debug and could start that, too.
Then i tried compiling my own code, so i used the existing project bandwidthTest and copied my code in the file bandwidthTest.cu.
When i compile the code i get the following error:
The Code i tried to compile:
#include <cuda.h>
const int N = 1024;
const int blocksize = 16;
__global__ void add_matrix(float* a, float *b, float *c, int N)
int i = blockIdx.x * blockDim.x + threadIdx.x;
int j = blockIdx.y * blockDim.y + threadIdx.y;
int index = i + j*N;
if (i < N && j < N)
c[index] = a[index] + b[index];
int main() {
float *a = new float[N*N];
float *b = new float[N*N];
float *c = new float[N*N];
for ( int i = 0; i < N*N; ++i ) {
a[i] = 1.0f; b[i] = 3.5f;
float *ad, *bd, *cd;
const int size = N*N*sizeof(float);
cudaMalloc( (void**)&ad, size );
cudaMalloc( (void**)&bd, size );
cudaMalloc( (void**)&cd, size );
cudaMemcpy( ad, a, size, cudaMemcpyHostToDevice );
cudaMemcpy( bd, b, size, cudaMemcpyHostToDevice );
dim3 dimBlock( blocksize, blocksize );
dim3 dimGrid( N/dimBlock.x, N/dimBlock.y );
add_matrix<<<dimGrid, dimBlock>>>( ad, bd, cd, N );
cudaMemcpy( c, cd, size, cudaMemcpyDeviceToHost );
cudaFree( ad ); cudaFree( bd ); cudaFree( cd );
delete[] a; delete[] b; delete[] c;
return EXIT_SUCCESS;
Does anybody have an idea what i am doing wrong or how i can compile this simple code?
http://stackoverflow.com/questions/7233291/visual-studio-express-simple-build-configuration-error
ok got that running now, thx ;)
i now want to measure the execution time of this snippet as following:
 * Copyright 1993-2011 NVIDIA Corporation.  All rights reserved.
 * Please refer to the NVIDIA end user license agreement (EULA) associated
 * with this source code for terms and conditions that govern your use of
 * this software. Any use, reproduction, disclosure, or distribution of
 * this software and related documentation outside the terms of the EULA
 * is strictly prohibited.
 * This is a simple test program to measure the memcopy bandwidth of the GPU.
 * It can measure device to device copy bandwidth, host to device copy bandwidth
 * for pageable and pinned memory, and device to host copy bandwidth for pageable
 * and pinned memory.
 * Usage:
 * ./bandwidthTest [option]...
// includes
//#include <sdkHelper.h>  // helper for shared functions common to CUDA SDK samples
//#include <shrQATest.h> // This is for automated testing output (--qatest)
//#include <shrUtils.h>
#include <memory>
#include <iostream>
#include <cassert>
#include <stdio.h>
#include <cuda.h>
#include <Winsock2.h>
#include <time.h>
#include <windows.h>
#if defined(_MSC_VER) || defined(_MSC_EXTENSIONS)
  #define DELTA_EPOCH_IN_MICROSECS  11644473600000000Ui64
#else
  #define DELTA_EPOCH_IN_MICROSECS  11644473600000000ULL
#endif
struct timezone
  int  tz_minuteswest; /* minutes W of Greenwich */
  int  tz_dsttime;     /* type of dst correction */
int gettimeofday(struct timeval *tv, struct timezone *tz)
// Define a structure to receive the current Windows filetime
  FILETIME ft;
// Initialize the present time to 0 and the timezone to UTC
  unsigned __int64 tmpres = 0;
  static int tzflag = 0;
if (NULL != tv)
    GetSystemTimeAsFileTime(&ft);
// The GetSystemTimeAsFileTime returns the number of 100 nanosecond
// intervals since Jan 1, 1601 in a structure. Copy the high bits to
// the 64 bit tmpres, shift it left by 32 then or in the low 32 bits.
    tmpres |= ft.dwHighDateTime;
    tmpres <<= 32;
    tmpres |= ft.dwLowDateTime;
// Convert to microseconds by dividing by 10
    tmpres /= 10;
// The Unix epoch starts on Jan 1 1970.  Need to subtract the difference
// in seconds from Jan 1 1601.
    tmpres -= DELTA_EPOCH_IN_MICROSECS;
// Finally change microseconds to seconds and place in the seconds value.
// The modulus picks up the microseconds.
    tv->tv_sec = (long)(tmpres / 1000000UL);
    tv->tv_usec = (long)(tmpres % 1000000UL);
if (NULL != tz)
    if (!tzflag)
      _tzset();
      tzflag++;
// Adjust for the timezone west of Greenwich
      tz->tz_minuteswest = _timezone / 60;
    tz->tz_dsttime = _daylight;
return 0;
const int N = 4096;
const int blocksize = 64;
struct timeval start_time;
struct timeval end_time;
int compute_result(struct timeval *end_time, struct timeval *start_time) {
if(end_time->tv_sec == 0 && end_time->tv_usec == 0) {
        return 0;
    return (end_time->tv_sec * 1000 + end_time->tv_usec / 1000) - (start_time->tv_sec * 1000 + start_time->tv_usec / 1000);
if (i < N && j < N)
int main() {
gettimeofday(&start_time, NULL);
double t1=start_time.tv_sec+(start_time.tv_usec/1000000.0);
printf("start: %d\n", t1);
gettimeofday(&end_time, NULL);
double t2=end_time.tv_sec+(end_time.tv_usec/1000000.0);
printf("start: %d\n", t2);
//printf("Ergebnis: %d", compute_result(&end_time, &start_time));
printf("Ergebnis: %f", t2-t1);
but the timedifference is always 0 …
if i run the standard c version of this program i get some ms as result …
i also found this to measure time:
cudaEvent_t start, stop;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord( start, 0 );
// your code
cudaEventRecord( stop, 0 );
cudaEventSynchronize( stop );
float elapsedTime;
cudaEventElapsedTime( &elapsedTime, start, stop );
printf( "Time to generate: %3.1f ms\n", elapsedTime );
but if i replace //your code with my kernel-call its 0.00ms aswell …
CUDA launches are asynchronous.
If you want to do timing from the host side, you need to synchronize either using cudaMemcpy or with explicit synchronization ( cudaDeviceSynchronize )
You should modify your code to:
cudaDeviceSynchronize();
after you call a kernel the control is given back to the host. you need to sync the host and the gpu. try this:
float gputime;
    cudaEvent_t start,stop;
cudaEventRecord(start,0);
// ... gpu work
cudaEventRecord(stop,0);
    cudaEventSynchronize(stop);
    cudaEventElapsedTime(&gputime,start,stop);
cudaEventDestroy(start);
    cudaEventDestroy(stop) ;
    printf(" \n");
printf("Time = %g \n",  gputime/1000.0f);
ah thx mfatica :)
cudaDeviceSynchronize(); works
Still it is better to use the cuda events to time the code. Refer to Cuda C Best Practice Guide Chapter 5 for more information on timing and performance metrics. (it is only 5 pages)
cheers,
Are these methods effective to usse them when mpi or openmo barriers are used ? In cases some communication between threads/processes are needed.
