Problem with complex constant in pgf90 v14.1
I’m trying to compile the following code with pgf90 (v14.1):
module constant
complex, constant,public :: cmplx_0_d=(0.0,0.0)
end module constant
program test
use constant
implicit none
complex, device :: a
complex :: b
b = cmplx(1.0,1.0)
a = cmplx_0_d
b = a
write(,) b
end program test
I get the following error when compiling:
[adrianj@hydra]$ pgf90 -acc -Minfo=all -o test constant.CUF test.CUF
constant.CUF:
/home/h018/adrianj/temp/pgcudaforJjHbPlEc6IQb.gpu(6): error: expected a “}”
1 error detected in the compilation of “/home/h018/adrianj/temp/pgnvd-kHb9-D1qqHE.nv0”.
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (constant.CUF: 1)
PGF90/x86-64 Linux 14.1-0: compilation aborted
test.CUF:
Is a fortran complex type not allowed to be setup in the constant memory or is this just a compiler bug?
thanks
adrianj
Thanks adrianj. I’ve recreated the issue here and sent a report (TPR#20072) to our engineers for further investigation.
The work around would be to initialize the variable from executable host code.
module constant
 end module constant
 program test
 use constant
 implicit none
 complex :: b
 cmplx_0_d=(0.0,0.0)
 b = cmplx(1.0,1.0)
 a = cmplx_0_d
 b = a
 write(*,*) b
 end program test
Best regards,
Mat
thanks Mat
TPR 20072 - UF: Initializing a constant complex module varible give GPU syntax
has been fixed in the current 14.7 release.
thanks,
dave
