Problem with cuda 7 toolkit on centos 6.6
We purchased a tesla K80 and installed in a server running centos 6.6.
lspci | grep -i nvidia
44:00.0 3D controller: NVIDIA Corporation GK110BGL [Tesla K80] (rev a1)
45:00.0 3D controller: NVIDIA Corporation GK110BGL [Tesla K80] (rev a1)
uname -m && cat /etc/*release
x86_64
CentOS release 6.6 (Final)
I installed the driver using the wizard from here:
http://www.nvidia.com/Download/Find.aspx?lang=en-us
This installed driver verson 346.59:
modinfo /lib/modules/2.6.32-504.16.2.el6.x86_64/kernel/drivers/video/nvidia.ko
filename: /lib/modules/2.6.32-504.16.2.el6.x86_64/kernel/drivers/video/nvidia.ko
alias: char-major-195-*
version: 346.59
supported: external
license: NVIDIA
alias: pci:v000010DEd00000E00svsdbc04sc80i00*
alias: pci:v000010DEd00000AA3svsdbc0Bsc40i00*
alias: pci:v000010DEdsvsdbc03sc02i00
alias: pci:v000010DEdsvsdbc03sc00i00
depends: i2c-core
vermagic: 2.6.32-504.16.2.el6.x86_64 SMP mod_unload modversions
parm: NVreg_Mobile:int
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_RemapLimit:int
parm: NVreg_UpdateMemoryTypes:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_MapRegistersEarly:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_CheckPCIConfigSpace:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RmMsg:charp
parm: NVreg_AssignGpus:charp
I then installed the cuda toolkit using instructions from:
http://docs.nvidia.com/cuda/cuda-getting-started-guide-for-linux/index.html#axzz3ca8v4mMB
I chose the centos package release as recommended. This installed:
[root@genuse32 yum.repos.d]# rpm -qa | grep cuda
cuda-cusparse-7-0-7.0-28.x86_64
cuda-samples-7-0-7.0-28.x86_64
cuda-driver-dev-7-0-7.0-28.x86_64
cuda-npp-dev-7-0-7.0-28.x86_64
cuda-cufft-dev-7-0-7.0-28.x86_64
cuda-documentation-7-0-7.0-28.x86_64
cuda-7.0-28.x86_64
cuda-misc-headers-7-0-7.0-28.x86_64
cuda-curand-7-0-7.0-28.x86_64
cuda-cudart-7-0-7.0-28.x86_64
cuda-toolkit-7-0-7.0-28.x86_64
cuda-repo-rhel6-7-0-local-7.0-28.x86_64
cuda-cusolver-dev-7-0-7.0-28.x86_64
cuda-cublas-dev-7-0-7.0-28.x86_64
cuda-runtime-7-0-7.0-28.x86_64
cuda-license-7-0-7.0-28.x86_64
cuda-npp-7-0-7.0-28.x86_64
cuda-cufft-7-0-7.0-28.x86_64
cuda-visual-tools-7-0-7.0-28.x86_64
cuda-7-0-7.0-28.x86_64
cuda-cusparse-dev-7-0-7.0-28.x86_64
cuda-nvrtc-dev-7-0-7.0-28.x86_64
cuda-command-line-tools-7-0-7.0-28.x86_64
cuda-cusolver-7-0-7.0-28.x86_64
cuda-cublas-7-0-7.0-28.x86_64
cuda-drivers-346.46-0.x86_64
cuda-core-7-0-7.0-28.x86_64
cuda-curand-dev-7-0-7.0-28.x86_64
cuda-cudart-dev-7-0-7.0-28.x86_64
cuda-nvrtc-7-0-7.0-28.x86_64
I compiled all the sample scripts successfully as well. However, trying to run deviceQuery resulted in:
/usr/local/cuda/samples/NVIDIA_CUDA-7.0_Samples/bin/x86_64/linux/release/deviceQuery
/usr/local/cuda/samples/NVIDIA_CUDA-7.0_Samples/bin/x86_64/linux/release/deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
Running nvidia-smi results in:
nvidia-smi
Failed to initialize NVML: GPU access blocked by the operating system
Searching google all I have been able to find with any real value was a ubuntu thread from 2013 that indicated the kernel module installed is too new for the toolkit installed. It did not have a solution. Any help would be greatly appreciated!
Is there any way to get support from nvidia maybe? I can’t find anywhere to email them!
There is a “Contact Us” box on the developer.nvidia.com CUDA ZONE Resources site.
https://developer.nvidia.com/resources
