Hi all!
I have tried using cusparseDcsrsv_solve() to for solving matrix-vector equation, with matrix in CSR (Compressed Sparse Row) format. If I set matrix type to be CUSPARSE_MATRIX_TYPE_TRIANGULAR, I get status = 0 (CUSPARSE_STATUS_SUCCESS) and output CSR_X1 as {0.0,0.0,0.0} on calling cusparseDcsrsv_solve(), but the same status becomes 5 (CUSPARSE_STATUS_MAPPING_ERROR I suppose) when I set matrix type to be CUSPARSE_MATRIX_TYPE_GENERAL. Please help me out regarding this.
A simple matrix I have considered is:
3.0 0.0 0.0
4.0 1.0 0.0
0.0 3.0 2.0
The right hand side vector is:
3.0
6.0
10.0
The matrix when converted to CSR format will be:
Value-- 3.0 4.0 1.0 3.0 2.0
Column- 0 0 1 1 2
Ptr---- 0 1 3 5
The following is the code for the same.
void fun1()
int espmat1=5,neq1=3; //espmat1 is equivalent of nnz (number of non-zero elements) in standard defintions
double csr_MATGLB1[] = {3.0,4.0,1.0,3.0,2.0};
int csr_colIND1[] = {0,0,1,1,2};
int csr_rowPTR1[] = {0,1,3,5};
double csr_X1[neq1];
double csr_R1[] = {3.0,6.0,10.0};
getSolver(neq1,espmat1,csr_MATGLB1,csr_colIND1,csr_rowPTR1,csr_X1,csr_R1,ret_csr_MATGLB1,ret_csr_colIND1,ret_csr_rowPTR1);
v_print(csr_X1,3,"X1 solved");
cudaError_t getSolver(int neq,int espmat,double *matrix,int *index,int *ptr,double *Xvec,double *Rvec,double *retmat,int *retind,int *retptr)
cudaError_t cudaStatus;
double *dev_csr_MATGLB=NULL,*dev_X=NULL,*dev_RGLB=NULL;
int *dev_csr_rowPTR=NULL,*dev_csr_colINDEX=NULL;
cudaMalloc(&dev_csr_MATGLB,espmat*sizeof(double));
cudaMemcpy(dev_csr_MATGLB,matrix,espmat*sizeof(double),cudaMemcpyHostToDevice);
cudaStatus = cudaGetLastError();
if (cudaStatus != cudaSuccess) {
fprintf(stderr, "1---kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
return cudaStatus;
cudaMalloc(&dev_csr_colINDEX,espmat*sizeof(int));
cudaMemcpy(dev_csr_colINDEX,index,espmat*sizeof(int),cudaMemcpyHostToDevice);
fprintf(stderr, "2---kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
return cudaStatus;
cudaMalloc(&dev_csr_rowPTR,(neq+1)*sizeof(int));
cudaMemcpy(dev_csr_rowPTR,ptr,(neq+1)*sizeof(int),cudaMemcpyHostToDevice);
fprintf(stderr, "3---kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
return cudaStatus;
cudaMalloc(&dev_X,neq*sizeof(double));
cudaMalloc(&dev_RGLB,neq*sizeof(double));
cudaMemcpy(dev_RGLB,Rvec,neq*sizeof(double),cudaMemcpyHostToDevice);
fprintf(stderr, "4---kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
return cudaStatus;
printf("\n****************SUCCESS Solver part Initialised**************************\n");
cusparseStatus_t status;
cusparseHandle_t handle=0;
cusparseMatDescr_t descr=0;
cusparseSolveAnalysisInfo_t info=0;
cusparseOperation_t trans = CUSPARSE_OPERATION_NON_TRANSPOSE;
double alpha = 1.00;
status= cusparseCreate(&handle);
if (status != CUSPARSE_STATUS_SUCCESS)
printf("CUSPARSE Library initialization failed\n");
// create and setup matrix descriptor
status= cusparseCreateMatDescr(&descr);
printf("Matrix descriptor initialization failed\n");
status = cusparseCreateSolveAnalysisInfo(&info);
printf("Solve analysis info initialization failed\n");
cusparseSetMatType(descr,CUSPARSE_MATRIX_TYPE_TRIANGULAR);
cusparseSetMatIndexBase(descr,CUSPARSE_INDEX_BASE_ZERO);
//SOLVER
status = cusparseDcsrsv_solve(handle,trans,neq,&alpha,descr,dev_csr_MATGLB,dev_csr_rowPTR,dev_csr_colINDEX,info,dev_RGLB,dev_X);
printf("Solve status: %d\n",status);
cudaMemcpy(Xvec,dev_X,neq*sizeof(double),cudaMemcpyDeviceToHost);
fprintf(stderr, "5---kernel launch failed: %s\n", cudaGetErrorString(cudaStatus));
return cudaStatus;
printf("\n****************SUCCESS Solver part Solved**************************\n");
cudaStatus = cudaDeviceSynchronize();
fprintf(stderr, "cudaDeviceSynchronize returned error code %d after launching kernel!\n", cudaStatus);
return cudaStatus;
cudaFree(dev_csr_MATGLB);
cudaFree(dev_X);
cudaFree(dev_RGLB);
cudaFree(dev_csr_rowPTR);
cudaFree(dev_csr_colINDEX);
