I just installed fresh CUDA 2.1 and VS 2008 (C++ express edition). I used the CUDA VS wizard to set up. I also copied cutil32d.dll from SDK root to c:\cuda\bin so that VS can actually build the file (or else, it would not compile and give a missing dll error)
Everything seems to be fine at the moment except that when I set a break point within a kernel and run in Emudebug mode, the program stops successfully at the break point. However, it cannot progress more than 1 step from that position and it gives me an error
“There is no source code available for the current location.”
when I try to progress. I have no idea how to go around this issue. Please do share any thoughts helpful solving this problem.
Edit: Instead of copying the dll files, I added relevant directory to the PATH environment variable. Compiling works fine as expected, but the debugger still does not work, not surprisingly.
Also, I realized that the problem is not just for emudebug. It occurs for the regular debugger as well. So, basically I cannot step through the functions at all.
