Problem with Destructor
Hi guys
I have a class into my app, some thing like this:
class SwitchPort : public Port
      public:
        	//Constructor
 		SwitchPort();
 		 SwitchPort(unsigned char local_id, unsigned short parent);
 		void Init(unsigned char local_id, unsigned short parent);
 		Type_Port Type; //This is an enum
 		Neighbor myNeighbor; //this is a class object
		  //Destructor
 		~SwitchPort();
When I creates and object of type Switchport into the main function the app work fine, but when I creates this object into the kernel, I get the error
The destructor for Switchport and Neighbor are declared as device host.
However, I always im getting this message.
Why the constructor is supported and the destructor does not?
Thanks in advance
Your question is not entirely clear to me, but I hope this helps:
Did you make sure that the constructors and destructors of the class you instantiate in the kernel are declared with the host device specifiers? Like so:
class A
    int member;
    public:
        __device__ __host__ A(int x)
            member(x)
        __device__ __host__ ~A()
In your class, some of your members are instantiations of different classes, which should also be declared like the example above.
