In a laptop ASUS N552VW with a gtx 960M all works well with Kubuntu 20.10 and 455.45 driver. The Kubuntu OS starts normally, and connecting an external monitor with hdmi it is detected correctly, but when the system is rebooted with external hdmi monitor the graphical login is not showed.
I think with more details someone could help me, as I had tell when the system start without the external hdmi monitor all look fine:
$ prime-select query
nvidia
uname -sr
Linux 5.8.0-44-generic
nvidia-smi
Sun Feb 28 08:05:03 2021
| NVIDIA-SMI 460.39 Driver Version: 460.39 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce GTX 960M Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P8 N/A / N/A | 459MiB / 4046MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1447 G /usr/lib/xorg/Xorg 253MiB |
| 0 N/A N/A 2544 G /usr/bin/kwin_x11 53MiB |
| 0 N/A N/A 2588 G /usr/bin/plasmashell 41MiB |
| 0 N/A N/A 3300 G ...gAAAAAAAAA --shared-files 66MiB |
| 0 N/A N/A 6803 G /usr/bin/systemsettings5 36MiB |
xrandr without external hdmi minitor:
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
3840x2160 59.98 + 59.98 59.97
3200x1800 59.96 59.94
2880x1620 59.96 59.97
2560x1600 59.99 59.97
2560x1440 59.99 59.99 59.96 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96* 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
xrandr after external hdmi monitor connected:
$ xrandr
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 16384 x 16384
eDP-1-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
1920x1080 60.01 59.97 59.96 59.93*
1600x1200 60.00
1600x1024 60.17
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1152x864 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 59.93 60.00
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00 + 50.00 59.94*
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
$ sudo dmesg | grep -i nvidia
[sudo] password for andrea:
[ 1.169241] nvidia: loading out-of-tree module taints kernel.
[ 1.169252] nvidia: module license 'NVIDIA' taints kernel.
[ 1.217904] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 1.334055] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.39 Thu Jan 21 21:54:06 UTC 2021
[ 4.271928] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 460.39 Thu Jan 21 21:49:04 UTC 2021
[ 4.295179] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.763577] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 4.797120] nvidia_uvm: module verification failed: signature and/or required key missing - tainting kernel
[ 4.800732] nvidia-uvm: Loaded the UVM driver, major device number 510.
[ 5.418406] audit: type=1400 audit(1614437803.290:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1081 comm="apparmor_parser"
[ 5.418416] audit: type=1400 audit(1614437803.290:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1081 comm="apparmor_parser"
So, with the system in the previous situation, when I reboot the system the situation is the follow:
First of all during the startup the grub menu is shown only on the external hdmi monitor, instead the laptop monitor seems disabled.
After selected the usual one voice in the grub menu, the “kubuntu” log is shown for a couple of second so the exenal monitor enters in the standby mode, now the only possibility to interct with the system is using “ctrl+F2” for a terminal console, and in this situation I gave the command
nvidia-bug-report.sh
I hope someone can help me, thanks
nvidia-bug-report.log.gz (315.5 KB)
Please try adding xrandr command to sddm
https://wiki.archlinux.org/index.php/NVIDIA_Optimus#SDDM
Hi generix, thanks for the response, I have changed the file Xsetup from :
#!/bin/sh
# Xsetup - run as root before the login dialog appears
if [ -e /sbin/prime-offload ]; then
echo running NVIDIA Prime setup /sbin/prime-offload
/sbin/prime-offload
fi
to:
#!/bin/sh
/sbin/prime-offload
fi
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
but the result is the same
Does this also happen when you switch to intel mode?
Changing from prime-select nvidia to prime-select intel after the reboot, the laptop monitor seems always disabled, but now on the hdmi external monitor login after “kubuntu” logo is shown.
After login the result of the command xrandr:
$ xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
15360x8640 15.83 28.85
7680x4320 15.83 59.99 59.99 59.99
5120x2880 59.99 59.99
4096x2304 59.99 59.98
3840x2160 60.00 60.01 59.98 59.97
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
1600x1200 60.00
1600x1024 60.17
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1152x864 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 59.93 60.00
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1680x1050 59.88
1600x900 60.00
1440x900 59.90
1280x800 59.91
1152x864 75.00
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
But the eDP-1 seems off.
can you enable it in kde control center?
There seems to be something wrong with either the intel gpu or its i915 driver. Please check for a bios update.
The laptop a n552vw-fi057t has the latest version of bios (2019)
Did this previously work at any time, e.g. with an earlier kernel/Ubuntu install?
Sorry for delay, I have used for the first time an external monitor connected with HDMI with ubuntu 18.10 and the problem was present. It was the presence of this problem to made me upgrade the ubuntu ad 20.10 with the hope the problem was solved.
I brief the response is no :/
Please attach a dmesg output taken while in intel only mode.
Hi Generix, thanks for the support, following the dmesg output after prime-selection intel:
[ 0.000000] microcode: microcode updated early to revision 0xe2, date = 2020-07-14
[ 0.000000] Linux version 5.8.0-44-generic (buildd@lgw01-amd64-039) (gcc (Ubuntu 10.2.0-13ubuntu1) 10.2.0, GNU ld (GNU Binutils for Ubuntu) 2.35.1) #50-Ubuntu SMP Tue Feb 9 06:29:41 UTC 2021 (Ubuntu 5.8.0-44.50-generic 5.8.18)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.8.0-44-generic root=UUID=2c8a9580-f1a7-4046-a2ab-993f3a95eb6e ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000071772fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000071773000-0x0000000071773fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000071774000-0x00000000717bdfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000717be000-0x000000007180ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000071810000-0x0000000071c50fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000071c51000-0x0000000075c99fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000075c9a000-0x0000000076728fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000076729000-0x0000000076982fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000076983000-0x0000000077326fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000077327000-0x0000000077f7efff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000077f7f000-0x0000000077ffefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078000000-0x00000000780fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000483ffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] e820: update [mem 0x702a3018-0x702bcc57] usable ==> usable
[ 0.000000] e820: update [mem 0x70295018-0x702a2857] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000059000-0x000000000009dfff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000070295017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000070295018-0x00000000702a2857] usable
[ 0.000000] reserve setup_data: [mem 0x00000000702a2858-0x00000000702a3017] usable
[ 0.000000] reserve setup_data: [mem 0x00000000702a3018-0x00000000702bcc57] usable
[ 0.000000] reserve setup_data: [mem 0x00000000702bcc58-0x0000000071772fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000071773000-0x0000000071773fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000071774000-0x00000000717bdfff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000717be000-0x000000007180ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000071810000-0x0000000071c50fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000071c51000-0x0000000075c99fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000075c9a000-0x0000000076728fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000076729000-0x0000000076982fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000076983000-0x0000000077326fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000077327000-0x0000000077f7efff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000077f7f000-0x0000000077ffefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000078000000-0x00000000780fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x0000000483ffffff] usable
[ 0.000000] efi: EFI v2.40 by American Megatrends
[ 0.000000] efi: ESRT=0x77e47e18 ACPI=0x76a8b000 ACPI 2.0=0x76a8b000 SMBIOS=0x77861000 SMBIOS 3.0=0x77860000 TPMEventLog=0x71c5f018
[ 0.000000] [Firmware Bug]: TPM Final Events table missing or invalid
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. N552VW/N552VW, BIOS N552VW.304 05/08/2019
[ 0.000000] tsc: Detected 2600.000 MHz processor
[ 0.001152] tsc: Detected 2599.992 MHz TSC
[ 0.001152] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001153] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001159] last_pfn = 0x484000 max_arch_pfn = 0x400000000
[ 0.001162] MTRR default type: write-back
[ 0.001163] MTRR fixed ranges enabled:
[ 0.001164] 00000-9FFFF write-back
[ 0.001164] A0000-BFFFF uncachable
[ 0.001165] C0000-FFFFF write-protect
[ 0.001166] MTRR variable ranges enabled:
[ 0.001167] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.001167] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.001168] 2 base 007A000000 mask 7FFE000000 uncachable
[ 0.001169] 3 base 0079000000 mask 7FFF000000 uncachable
[ 0.001169] 4 base 0078800000 mask 7FFF800000 uncachable
[ 0.001170] 5 disabled
[ 0.001170] 6 disabled
[ 0.001170] 7 disabled
[ 0.001171] 8 disabled
[ 0.001171] 9 disabled
[ 0.001432] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001549] last_pfn = 0x77fff max_arch_pfn = 0x400000000
[ 0.008465] esrt: Reserving ESRT space from 0x0000000077e47e18 to 0x0000000077e47e50.
[ 0.008470] check: Scanning 1 areas for low memory corruption
[ 0.008474] Using GB pages for direct mapping
[ 0.009245] secureboot: Secure boot disabled
[ 0.009246] RAMDISK: [mem 0x39065000-0x3fffdfff]
[ 0.009255] ACPI: Early table checksum verification disabled
[ 0.009257] ACPI: RSDP 0x0000000076A8B000 000024 (v02 _ASUS_)
[ 0.009260] ACPI: XSDT 0x0000000076A8B0A8 0000D4 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009264] ACPI: FACP 0x0000000076AB1110 00010C (v05 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009267] ACPI: DSDT 0x0000000076A8B210 025EFE (v02 _ASUS_ Notebook 01072009 INTL 20120913)
[ 0.009270] ACPI: FACS 0x0000000077325F80 000040
[ 0.009271] ACPI: APIC 0x0000000076AB1220 0000BC (v03 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009273] ACPI: FPDT 0x0000000076AB12E0 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009275] ACPI: FIDT 0x0000000076AB1328 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009277] ACPI: MCFG 0x0000000076AB13C8 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.009279] ACPI: HPET 0x0000000076AB1408 000038 (v01 _ASUS_ Notebook 01072009 AMI. 0005000B)
[ 0.009281] ACPI: SSDT 0x0000000076AB1440 000315 (v01 SataRe SataTabl 00001000 INTL 20120913)
[ 0.009283] ACPI: ECDT 0x0000000076AB1758 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.009285] ACPI: LPIT 0x0000000076AB1820 000094 (v01 INTEL SKL 00000000 MSFT 0000005F)
[ 0.009287] ACPI: SSDT 0x0000000076AB18B8 000248 (v02 INTEL sensrhub 00000000 INTL 20120913)
[ 0.009289] ACPI: DBGP 0x0000000076AB1B00 000034 (v01 INTEL 00000000 MSFT 0000005F)
[ 0.009291] ACPI: DBG2 0x0000000076AB1B38 000054 (v00 INTEL 00000000 MSFT 0000005F)
[ 0.009293] ACPI: SSDT 0x0000000076AB1B90 003D69 (v02 DptfTa DptfTabl 00001000 INTL 20120913)
[ 0.009295] ACPI: SSDT 0x0000000076AB5900 006685 (v02 SaSsdt SaSsdt 00003000 INTL 20120913)
[ 0.009297] ACPI: UEFI 0x0000000076ABBF88 000042 (v01 00000000 00000000)
[ 0.009299] ACPI: SSDT 0x0000000076ABBFD0 000E58 (v02 CpuRef CpuSsdt 00003000 INTL 20120913)
[ 0.009301] ACPI: BGRT 0x0000000076ABCE28 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.009302] ACPI: SSDT 0x0000000076ABCE60 0000A5 (v02 SgRef SgPeg 00001000 INTL 20120913)
[ 0.009305] ACPI: DMAR 0x0000000076ABCF08 0000F0 (v01 INTEL SKL 00000001 INTL 00000001)
[ 0.009307] ACPI: TPM2 0x0000000076ABCFF8 000034 (v03 Tpm2Tabl 00000001 AMI 00000000)
[ 0.009309] ACPI: SSDT 0x0000000076ABD030 001A3F (v01 OptRef OptTabl 00001000 INTL 20120913)
[ 0.009311] ACPI: MSDM 0x00000000764C2F18 000055 (v03 _ASUS_ Notebook 00000000 ASUS 00000001)
[ 0.009318] ACPI: Local APIC address 0xfee00000
[ 0.009419] No NUMA configuration found
[ 0.009420] Faking a node at [mem 0x0000000000000000-0x0000000483ffffff]
[ 0.009428] NODE_DATA(0) allocated [mem 0x483fd5000-0x483ffefff]
[ 0.009701] Zone ranges:
[ 0.009702] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.009703] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.009704] Normal [mem 0x0000000100000000-0x0000000483ffffff]
[ 0.009704] Device empty
[ 0.009705] Movable zone start for each node
[ 0.009707] Early memory node ranges
[ 0.009708] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.009709] node 0: [mem 0x0000000000059000-0x000000000009dfff]
[ 0.009709] node 0: [mem 0x0000000000100000-0x0000000071772fff]
[ 0.009710] node 0: [mem 0x00000000717be000-0x000000007180ffff]
[ 0.009710] node 0: [mem 0x0000000071c51000-0x0000000075c99fff]
[ 0.009711] node 0: [mem 0x0000000076729000-0x0000000076982fff]
[ 0.009711] node 0: [mem 0x0000000077f7f000-0x0000000077ffefff]
[ 0.009712] node 0: [mem 0x0000000100000000-0x0000000483ffffff]
[ 0.009906] Zeroed struct page in unavailable ranges: 25980 pages
[ 0.009907] Initmem setup node 0 [mem 0x0000000000001000-0x0000000483ffffff]
[ 0.009908] On node 0 totalpages: 4168324
[ 0.009909] DMA zone: 64 pages used for memmap
[ 0.009909] DMA zone: 21 pages reserved
[ 0.009910] DMA zone: 3996 pages, LIFO batch:0
[ 0.009928] DMA32 zone: 7468 pages used for memmap
[ 0.009929] DMA32 zone: 477928 pages, LIFO batch:63
[ 0.012380] Normal zone: 57600 pages used for memmap
[ 0.012380] Normal zone: 3686400 pages, LIFO batch:63
[ 0.031533] Reserving Intel graphics memory at [mem 0x79000000-0x7affffff]
[ 0.031821] ACPI: PM-Timer IO Port: 0x1808
[ 0.031823] ACPI: Local APIC address 0xfee00000
[ 0.031828] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.031828] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.031829] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.031829] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.031830] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.031830] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.031830] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.031831] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.031857] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.031859] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.031860] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.031860] ACPI: IRQ0 used by override.
[ 0.031861] ACPI: IRQ9 used by override.
[ 0.031863] Using ACPI (MADT) for SMP configuration information
[ 0.031864] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.031868] e820: update [mem 0x74943000-0x74971fff] usable ==> reserved
[ 0.031875] TSC deadline timer available
[ 0.031876] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.031893] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.031894] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.031896] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.031896] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.031897] PM: hibernation: Registered nosave memory: [mem 0x70295000-0x70295fff]
[ 0.031898] PM: hibernation: Registered nosave memory: [mem 0x702a2000-0x702a2fff]
[ 0.031899] PM: hibernation: Registered nosave memory: [mem 0x702a3000-0x702a3fff]
[ 0.031900] PM: hibernation: Registered nosave memory: [mem 0x702bc000-0x702bcfff]
[ 0.031901] PM: hibernation: Registered nosave memory: [mem 0x71773000-0x71773fff]
[ 0.031901] PM: hibernation: Registered nosave memory: [mem 0x71774000-0x717bdfff]
[ 0.031903] PM: hibernation: Registered nosave memory: [mem 0x71810000-0x71c50fff]
[ 0.031904] PM: hibernation: Registered nosave memory: [mem 0x74943000-0x74971fff]
[ 0.031905] PM: hibernation: Registered nosave memory: [mem 0x75c9a000-0x76728fff]
[ 0.031906] PM: hibernation: Registered nosave memory: [mem 0x76983000-0x77326fff]
[ 0.031907] PM: hibernation: Registered nosave memory: [mem 0x77327000-0x77f7efff]
[ 0.031908] PM: hibernation: Registered nosave memory: [mem 0x77fff000-0x77ffffff]
[ 0.031908] PM: hibernation: Registered nosave memory: [mem 0x78000000-0x780fffff]
[ 0.031909] PM: hibernation: Registered nosave memory: [mem 0x78100000-0x78ffffff]
[ 0.031909] PM: hibernation: Registered nosave memory: [mem 0x79000000-0x7affffff]
[ 0.031910] PM: hibernation: Registered nosave memory: [mem 0x7b000000-0xdfffffff]
[ 0.031910] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.031910] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.031911] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.031911] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.031911] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.031912] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.031912] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.031913] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.031913] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.031914] [mem 0x7b000000-0xdfffffff] available for PCI devices
[ 0.031915] Booting paravirtualized kernel on bare hardware
[ 0.031917] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.031922] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.032052] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.032058] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.032058] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.032080] Built 1 zonelists, mobility grouping on. Total pages: 4103171
[ 0.032080] Policy zone: Normal
[ 0.032081] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8.0-44-generic root=UUID=2c8a9580-f1a7-4046-a2ab-993f3a95eb6e ro quiet splash vt.handoff=7
[ 0.032715] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.032994] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.033055] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.062928] Memory: 16086864K/16673296K available (14339K kernel code, 2536K rwdata, 8800K rodata, 2644K init, 4912K bss, 586432K reserved, 0K cma-reserved)
[ 0.062934] random: get_random_u64 called from kmem_cache_open+0x2b/0x240 with crng_init=0
[ 0.063041] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.063053] Kernel/User page tables isolation: enabled
[ 0.063068] ftrace: allocating 48628 entries in 190 pages
[ 0.077288] ftrace: allocated 190 pages with 6 groups
[ 0.077386] rcu: Hierarchical RCU implementation.
[ 0.077387] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[ 0.077388] Trampoline variant of Tasks RCU enabled.
[ 0.077388] Rude variant of Tasks RCU enabled.
[ 0.077388] Tracing variant of Tasks RCU enabled.
[ 0.077389] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.077389] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.080130] NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
[ 0.080516] random: crng done (trusting CPU's manufacturer)
[ 0.080547] spurious 8259A interrupt: IRQ7.
[ 0.080565] vt handoff: transparent VT on vt#7
[ 0.080571] Console: colour dummy device 80x25
[ 0.080574] printk: console [tty0] enabled
[ 0.080589] ACPI: Core revision 20200528
[ 0.080835] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.080935] APIC: Switch to symmetric I/O mode setup
[ 0.080937] DMAR: Host address width 39
[ 0.080938] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.080942] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0501e
[ 0.080943] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.080945] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.080946] DMAR: RMRR base: 0x000000764a2000 end: 0x000000764c1fff
[ 0.080947] DMAR: RMRR base: 0x00000078800000 end: 0x0000007affffff
[ 0.080948] DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x0000000078800000-0x000000007affffff], contact BIOS vendor for fixes
[ 0.080950] DMAR: [Firmware Bug]: Your BIOS is broken; bad RMRR [0x0000000078800000-0x000000007affffff]
BIOS vendor: American Megatrends Inc.; Ver: N552VW.304; Product Version: 1.0
[ 0.080950] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[ 0.080951] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[ 0.080952] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.080953] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.080953] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.080954] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.082435] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 0.082436] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.086374] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.104800] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[ 0.104803] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.98 BogoMIPS (lpj=10399968)
[ 0.104805] pid_max: default: 32768 minimum: 301
[ 0.107806] LSM: Security Framework initializing
[ 0.107815] Yama: becoming mindful.
[ 0.107833] AppArmor: AppArmor initialized
[ 0.107891] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.107915] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.108143] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.108159] process: using mwait in idle threads
[ 0.108161] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.108161] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.108163] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.108164] Spectre V2 : Mitigation: Full generic retpoline
[ 0.108165] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.108165] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.108166] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.108167] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.108168] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.108170] TAA: Mitigation: Clear CPU buffers
[ 0.108172] SRBDS: Mitigation: Microcode
[ 0.108172] MDS: Mitigation: Clear CPU buffers
[ 0.108394] Freeing SMP alternatives memory: 40K
[ 0.110985] smpboot: CPU0: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (family: 0x6, model: 0x5e, stepping: 0x3)
[ 0.111090] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.111095] ... version: 4
[ 0.111096] ... bit width: 48
[ 0.111096] ... generic registers: 4
[ 0.111097] ... value mask: 0000ffffffffffff
[ 0.111097] ... max period: 00007fffffffffff
[ 0.111097] ... fixed-purpose events: 3
[ 0.111098] ... event mask: 000000070000000f
[ 0.111128] rcu: Hierarchical SRCU implementation.
[ 0.111847] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.111909] smp: Bringing up secondary CPUs ...
[ 0.111975] x86: Booting SMP configuration:
[ 0.111976] .... node #0, CPUs: #1 #2 #3 #4
[ 0.117039] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.117039] TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
[ 0.117039] #5 #6 #7
[ 0.117266] smp: Brought up 1 node, 8 CPUs
[ 0.117266] smpboot: Max logical packages: 1
[ 0.117266] smpboot: Total of 8 processors activated (41599.87 BogoMIPS)
[ 0.121255] devtmpfs: initialized
[ 0.121255] x86/mm: Memory block size: 128MB
[ 0.121682] PM: Registering ACPI NVS region [mem 0x71773000-0x71773fff] (4096 bytes)
[ 0.121682] PM: Registering ACPI NVS region [mem 0x76983000-0x77326fff] (10108928 bytes)
[ 0.121682] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.121682] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.121682] pinctrl core: initialized pinctrl subsystem
[ 0.121682] PM: RTC time: 06:10:20, date: 2021-03-08
[ 0.121682] thermal_sys: Registered thermal governor 'fair_share'
[ 0.121682] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.121682] thermal_sys: Registered thermal governor 'step_wise'
[ 0.121682] thermal_sys: Registered thermal governor 'user_space'
[ 0.121682] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.121682] NET: Registered protocol family 16
[ 0.121682] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.121682] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.121682] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.121682] audit: initializing netlink subsys (disabled)
[ 0.121682] audit: type=2000 audit(1615183820.040:1): state=initialized audit_enabled=0 res=1
[ 0.121682] EISA bus registered
[ 0.121682] cpuidle: using governor ladder
[ 0.121682] cpuidle: using governor menu
[ 0.121682] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.121682] ACPI: bus type PCI registered
[ 0.121682] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.121682] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.121682] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.121682] PCI: Using configuration type 1 for base access
[ 0.121682] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.125126] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.125126] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.125126] ACPI: Added _OSI(Module Device)
[ 0.125126] ACPI: Added _OSI(Processor Device)
[ 0.125126] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.125126] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.125126] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.125126] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.125126] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.167271] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.168910] ACPI: EC: EC started
[ 0.168910] ACPI: EC: interrupt blocked
[ 0.170891] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.170891] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.172237] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.178987] ACPI: Dynamic OEM Table Load:
[ 0.178992] ACPI: SSDT 0xFFFF9687F1592800 0005DC (v02 PmRef Cpu0Ist 00003000 INTL 20120913)
[ 0.180542] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[ 0.181979] ACPI: Dynamic OEM Table Load:
[ 0.181983] ACPI: SSDT 0xFFFF9687F0CC1000 00037F (v02 PmRef Cpu0Cst 00003001 INTL 20120913)
[ 0.183452] ACPI: Dynamic OEM Table Load:
[ 0.183455] ACPI: SSDT 0xFFFF9687F158E600 00008E (v02 PmRef Cpu0Hwp 00003000 INTL 20120913)
[ 0.184807] ACPI: Dynamic OEM Table Load:
[ 0.184810] ACPI: SSDT 0xFFFF9687F0C67A00 000130 (v02 PmRef HwpLvt 00003000 INTL 20120913)
[ 0.186933] ACPI: Dynamic OEM Table Load:
[ 0.186937] ACPI: SSDT 0xFFFF9687F1590800 0005AA (v02 PmRef ApIst 00003000 INTL 20120913)
[ 0.188693] ACPI: Dynamic OEM Table Load:
[ 0.188696] ACPI: SSDT 0xFFFF9687F0C65400 000119 (v02 PmRef ApHwp 00003000 INTL 20120913)
[ 0.190136] ACPI: Dynamic OEM Table Load:
[ 0.190139] ACPI: SSDT 0xFFFF9687F0C66C00 000119 (v02 PmRef ApCst 00003000 INTL 20120913)
[ 0.196652] ACPI: Interpreter enabled
[ 0.196685] ACPI: (supports S0 S3 S4 S5)
[ 0.196686] ACPI: Using IOAPIC for interrupt routing
[ 0.196718] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.197357] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.199984] ACPI: Power Resource [PG00] (on)
[ 0.226410] ACPI: Power Resource [PG01] (on)
[ 0.226824] ACPI: Power Resource [PG02] (on)
[ 0.227562] ACPI: Power Resource [WRST] (off)
[ 0.227922] ACPI: Power Resource [WRST] (off)
[ 0.228282] ACPI: Power Resource [WRST] (off)
[ 0.228640] ACPI: Power Resource [WRST] (off)
[ 0.229017] ACPI: Power Resource [WRST] (off)
[ 0.229370] ACPI: Power Resource [WRST] (off)
[ 0.229715] ACPI: Power Resource [WRST] (off)
[ 0.230353] ACPI: Power Resource [WRST] (off)
[ 0.230735] ACPI: Power Resource [WRST] (off)
[ 0.231151] ACPI: Power Resource [WRST] (off)
[ 0.231765] ACPI: Power Resource [WRST] (off)
[ 0.232111] ACPI: Power Resource [WRST] (off)
[ 0.232455] ACPI: Power Resource [WRST] (off)
[ 0.232800] ACPI: Power Resource [WRST] (off)
[ 0.233152] ACPI: Power Resource [WRST] (off)
[ 0.233500] ACPI: Power Resource [WRST] (off)
[ 0.233847] ACPI: Power Resource [WRST] (off)
[ 0.234208] ACPI: Power Resource [WRST] (off)
[ 0.234552] ACPI: Power Resource [WRST] (off)
[ 0.234901] ACPI: Power Resource [WRST] (off)
[ 0.245812] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.245817] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.247456] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[ 0.247457] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.248055] PCI host bridge to bus 0000:00
[ 0.248057] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.248058] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.248059] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.248059] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[ 0.248060] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[ 0.248061] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[ 0.248061] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[ 0.248062] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.248063] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.248063] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.248064] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.248065] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.248065] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.248066] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.248067] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.248068] pci_bus 0000:00: root bus resource [mem 0x7b000000-0xdfffffff window]
[ 0.248068] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ 0.248069] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.248077] pci 0000:00:00.0: [8086:1910] type 00 class 0x060000
[ 0.248187] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.248225] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.248422] pci 0000:00:02.0: [8086:191b] type 00 class 0x030000
[ 0.248431] pci 0000:00:02.0: reg 0x10: [mem 0xdd000000-0xddffffff 64bit]
[ 0.248435] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[ 0.248438] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.248451] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.248574] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.248583] pci 0000:00:04.0: reg 0x10: [mem 0xdf420000-0xdf427fff 64bit]
[ 0.248784] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[ 0.248802] pci 0000:00:14.0: reg 0x10: [mem 0xdf410000-0xdf41ffff 64bit]
[ 0.248861] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.249001] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[ 0.249019] pci 0000:00:14.2: reg 0x10: [mem 0xdf438000-0xdf438fff 64bit]
[ 0.249210] pci 0000:00:15.0: [8086:a160] type 00 class 0x118000
[ 0.249274] pci 0000:00:15.0: reg 0x10: [mem 0xdf437000-0xdf437fff 64bit]
[ 0.249598] pci 0000:00:15.1: [8086:a161] type 00 class 0x118000
[ 0.249650] pci 0000:00:15.1: reg 0x10: [mem 0xdf436000-0xdf436fff 64bit]
[ 0.249953] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[ 0.249976] pci 0000:00:16.0: reg 0x10: [mem 0xdf435000-0xdf435fff 64bit]
[ 0.250042] pci 0000:00:16.0: PME# supported from D3hot
[ 0.250194] pci 0000:00:17.0: [8086:a103] type 00 class 0x010601
[ 0.250209] pci 0000:00:17.0: reg 0x10: [mem 0xdf430000-0xdf431fff]
[ 0.250215] pci 0000:00:17.0: reg 0x14: [mem 0xdf434000-0xdf4340ff]
[ 0.250221] pci 0000:00:17.0: reg 0x18: [io 0xf090-0xf097]
[ 0.250226] pci 0000:00:17.0: reg 0x1c: [io 0xf080-0xf083]
[ 0.250232] pci 0000:00:17.0: reg 0x20: [io 0xf060-0xf07f]
[ 0.250238] pci 0000:00:17.0: reg 0x24: [mem 0xdf433000-0xdf4337ff]
[ 0.250272] pci 0000:00:17.0: PME# supported from D3hot
[ 0.250421] pci 0000:00:1c.0: [8086:a112] type 01 class 0x060400
[ 0.250488] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.250680] pci 0000:00:1c.3: [8086:a113] type 01 class 0x060400
[ 0.250746] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.250929] pci 0000:00:1c.4: [8086:a114] type 01 class 0x060400
[ 0.251000] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.251202] pci 0000:00:1f.0: [8086:a14e] type 00 class 0x060100
[ 0.251431] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[ 0.251445] pci 0000:00:1f.2: reg 0x10: [mem 0xdf42c000-0xdf42ffff]
[ 0.251623] pci 0000:00:1f.3: [8086:a170] type 00 class 0x040300
[ 0.251647] pci 0000:00:1f.3: reg 0x10: [mem 0xdf428000-0xdf42bfff 64bit]
[ 0.251676] pci 0000:00:1f.3: reg 0x20: [mem 0xdf400000-0xdf40ffff 64bit]
[ 0.251721] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.251924] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[ 0.251984] pci 0000:00:1f.4: reg 0x10: [mem 0xdf432000-0xdf4320ff 64bit]
[ 0.252055] pci 0000:00:1f.4: reg 0x20: [io 0xf040-0xf05f]
[ 0.252289] pci 0000:01:00.0: [10de:139b] type 00 class 0x030200
[ 0.252301] pci 0000:01:00.0: reg 0x10: [mem 0xde000000-0xdeffffff]
[ 0.252307] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.252314] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.252318] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.252322] pci 0000:01:00.0: reg 0x30: [mem 0xdf000000-0xdf07ffff pref]
[ 0.252334] pci 0000:01:00.0: Enabling HDA controller
[ 0.252375] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.252469] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.252471] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.252473] pci 0000:00:01.0: bridge window [mem 0xde000000-0xdf0fffff]
[ 0.252475] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.252731] pci 0000:02:00.0: [8086:095a] type 00 class 0x028000
[ 0.252781] pci 0000:02:00.0: reg 0x10: [mem 0xdf300000-0xdf301fff 64bit]
[ 0.253064] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.253516] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.253520] pci 0000:00:1c.0: bridge window [mem 0xdf300000-0xdf3fffff]
[ 0.253582] pci 0000:03:00.0: [10ec:5287] type 00 class 0xff0000
[ 0.253608] pci 0000:03:00.0: reg 0x10: [mem 0xdf215000-0xdf215fff]
[ 0.253661] pci 0000:03:00.0: reg 0x30: [mem 0xdf200000-0xdf20ffff pref]
[ 0.253745] pci 0000:03:00.0: supports D1 D2
[ 0.253746] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.253905] pci 0000:03:00.1: [10ec:8168] type 00 class 0x020000
[ 0.253930] pci 0000:03:00.1: reg 0x10: [io 0xd000-0xd0ff]
[ 0.253953] pci 0000:03:00.1: reg 0x18: [mem 0xdf214000-0xdf214fff 64bit]
[ 0.253968] pci 0000:03:00.1: reg 0x20: [mem 0xdf210000-0xdf213fff 64bit]
[ 0.254058] pci 0000:03:00.1: supports D1 D2
[ 0.254059] pci 0000:03:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.254190] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.254191] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.254194] pci 0000:00:1c.3: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.254293] pci 0000:04:00.0: [1b21:1242] type 00 class 0x0c0330
[ 0.254321] pci 0000:04:00.0: reg 0x10: [mem 0xdf100000-0xdf107fff 64bit]
[ 0.254370] pci 0000:04:00.0: enabling Extended Tags
[ 0.254441] pci 0000:04:00.0: PME# supported from D3hot D3cold
[ 0.254644] pci 0000:00:1c.4: PCI bridge to [bus 04]
[ 0.254647] pci 0000:00:1c.4: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.257090] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257148] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.257205] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257261] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257316] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257372] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257427] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.257483] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.258182] ACPI: EC: interrupt unblocked
[ 0.258182] ACPI: EC: event unblocked
[ 0.258193] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.258193] ACPI: EC: GPE=0x23
[ 0.258195] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot ECDT EC initialization complete
[ 0.258195] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.258287] iommu: Default domain type: Translated
[ 0.258287] SCSI subsystem initialized
[ 0.258287] libata version 3.00 loaded.
[ 0.258287] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.258287] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.258287] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.258287] vgaarb: loaded
[ 0.258287] ACPI: bus type USB registered
[ 0.258287] usbcore: registered new interface driver usbfs
[ 0.258287] usbcore: registered new interface driver hub
[ 0.258287] usbcore: registered new device driver usb
[ 0.258287] pps_core: LinuxPPS API ver. 1 registered
[ 0.258287] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.258287] PTP clock support registered
[ 0.258287] EDAC MC: Ver: 3.0.0
[ 0.258287] Registered efivars operations
[ 0.258287] NetLabel: Initializing
[ 0.258287] NetLabel: domain hash size = 128
[ 0.258287] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.258287] NetLabel: unlabeled traffic allowed by default
[ 0.258287] PCI: Using ACPI for IRQ routing
[ 0.287524] PCI: pci_cache_line_size set to 64 bytes
[ 0.287963] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.287964] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.287964] e820: reserve RAM buffer [mem 0x70295018-0x73ffffff]
[ 0.287965] e820: reserve RAM buffer [mem 0x702a3018-0x73ffffff]
[ 0.287966] e820: reserve RAM buffer [mem 0x71773000-0x73ffffff]
[ 0.287967] e820: reserve RAM buffer [mem 0x71810000-0x73ffffff]
[ 0.287968] e820: reserve RAM buffer [mem 0x74943000-0x77ffffff]
[ 0.287969] e820: reserve RAM buffer [mem 0x75c9a000-0x77ffffff]
[ 0.287970] e820: reserve RAM buffer [mem 0x76983000-0x77ffffff]
[ 0.287971] e820: reserve RAM buffer [mem 0x77fff000-0x77ffffff]
[ 0.287973] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.287973] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.289828] clocksource: Switched to clocksource tsc-early
[ 0.299032] VFS: Disk quotas dquot_6.6.0
[ 0.299043] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.299129] AppArmor: AppArmor Filesystem Enabled
[ 0.299150] pnp: PnP ACPI init
[ 0.299639] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.299641] system 00:00: [io 0xffff] has been reserved
[ 0.299642] system 00:00: [io 0xffff] has been reserved
[ 0.299643] system 00:00: [io 0x1800-0x18fe] has been reserved
[ 0.299644] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.299648] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.299734] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.299736] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.299752] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.299786] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.299788] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.299909] system 00:04: [io 0x0240-0x0259] has been reserved
[ 0.299911] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.299944] pnp 00:05: Plug and Play ACPI device, IDs ATK3001 PNP030b (active)
[ 0.300118] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.300119] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.300120] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.300121] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.300122] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.300123] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.300124] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.300124] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.300125] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.300127] system 00:06: [mem 0xdffe0000-0xdfffffff] has been reserved
[ 0.300129] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.300167] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[ 0.300168] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 0.300169] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 0.300170] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.300171] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 0.300172] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 0.300173] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[ 0.300175] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.300480] system 00:08: [io 0xff00-0xfffe] has been reserved
[ 0.300482] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.301707] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[ 0.301708] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[ 0.301709] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[ 0.301711] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.302633] pnp: PnP ACPI: found 10 devices
[ 0.308022] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.308069] NET: Registered protocol family 2
[ 0.308224] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.308313] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.308463] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.308532] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.308601] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.308637] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.308687] NET: Registered protocol family 1
[ 0.308690] NET: Registered protocol family 44
[ 0.308699] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.308701] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.308703] pci 0000:00:01.0: bridge window [mem 0xde000000-0xdf0fffff]
[ 0.308705] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.308708] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.308710] pci 0000:00:1c.0: bridge window [mem 0xdf300000-0xdf3fffff]
[ 0.308715] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.308716] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.308719] pci 0000:00:1c.3: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.308723] pci 0000:00:1c.4: PCI bridge to [bus 04]
[ 0.308726] pci 0000:00:1c.4: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.308731] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.308732] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.308733] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.308734] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[ 0.308734] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[ 0.308735] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[ 0.308736] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[ 0.308737] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[ 0.308737] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[ 0.308738] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[ 0.308739] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[ 0.308740] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[ 0.308740] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[ 0.308741] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[ 0.308742] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[ 0.308743] pci_bus 0000:00: resource 19 [mem 0x7b000000-0xdfffffff window]
[ 0.308743] pci_bus 0000:00: resource 20 [mem 0xfd000000-0xfe7fffff window]
[ 0.308744] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.308745] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[ 0.308746] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.308746] pci_bus 0000:02: resource 1 [mem 0xdf300000-0xdf3fffff]
[ 0.308747] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.308748] pci_bus 0000:03: resource 1 [mem 0xdf200000-0xdf2fffff]
[ 0.308749] pci_bus 0000:04: resource 1 [mem 0xdf100000-0xdf1fffff]
[ 0.308891] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.310311] PCI: CLS 0 bytes, default 64
[ 0.310341] Trying to unpack rootfs image as initramfs...
[ 0.501511] Freeing initrd memory: 114276K
[ 0.501595] DMAR: ACPI device "device:77" under DMAR at fed91000 as 00:15.0
[ 0.501597] DMAR: ACPI device "device:78" under DMAR at fed91000 as 00:15.1
[ 0.524860] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.524864] software IO TLB: mapped [mem 0x6c295000-0x70295000] (64MB)
[ 0.525174] check: Scanning for low memory corruption every 60 seconds
[ 0.525557] Initialise system trusted keyrings
[ 0.525574] Key type blacklist registered
[ 0.525600] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 0.526721] zbud: loaded
[ 0.526931] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.527058] fuse: init (API version 7.31)
[ 0.527163] integrity: Platform Keyring initialized
[ 0.534927] Key type asymmetric registered
[ 0.534928] Asymmetric key parser 'x509' registered
[ 0.534946] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.534975] io scheduler mq-deadline registered
[ 0.535275] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.535433] pcieport 0000:00:1c.0: PME: Signaling with IRQ 123
[ 0.535466] pcieport 0000:00:1c.0: AER: enabled with IRQ 123
[ 0.535630] pcieport 0000:00:1c.3: PME: Signaling with IRQ 124
[ 0.535662] pcieport 0000:00:1c.3: AER: enabled with IRQ 124
[ 0.535739] pcieport 0000:00:1c.4: PME: Signaling with IRQ 125
[ 0.535775] pcieport 0000:00:1c.4: AER: enabled with IRQ 125
[ 0.535839] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.535878] efifb: probing for efifb
[ 0.535890] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 0.535891] efifb: framebuffer at 0xb0000000, using 1876k, total 1875k
[ 0.535892] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 0.535892] efifb: scrolling: redraw
[ 0.535893] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.535919] fbcon: Deferring console take-over
[ 0.535920] fb0: EFI VGA frame buffer device
[ 0.535925] intel_idle: MWAIT substates: 0x11142120
[ 0.535926] intel_idle: v0.5.1 model 0x5E
[ 0.536258] intel_idle: Local APIC timer is reliable in all C-states
[ 0.536453] ACPI: AC Adapter [AC0] (on-line)
[ 0.536504] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.536514] ACPI: Lid Switch [LID]
[ 0.536531] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.536550] ACPI: Sleep Button [SLPB]
[ 0.536567] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.536580] ACPI: Power Button [PWRF]
[ 0.538614] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.538614] ACPI: Thermal Zone [THRM] (63 C)
[ 0.538831] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.541838] Linux agpgart interface v0.103
[ 0.545837] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 0.545842] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 0.549047] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 0.607983] loop: module loaded
[ 0.608274] libphy: Fixed MDIO Bus: probed
[ 0.608275] tun: Universal TUN/TAP device driver, 1.6
[ 0.608318] PPP generic driver version 2.4.2
[ 0.608353] VFIO - User Level meta-driver version: 0.3
[ 0.608413] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.608418] ehci-pci: EHCI PCI platform driver
[ 0.608427] ehci-platform: EHCI generic platform driver
[ 0.608437] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.608438] ohci-pci: OHCI PCI platform driver
[ 0.608445] ohci-platform: OHCI generic platform driver
[ 0.608452] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.608486] i8042: PNP: PS/2 Controller [PNP030b:PS2K] at 0x60,0x64 irq 1
[ 0.608487] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.609334] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.609449] mousedev: PS/2 mouse device common for all mice
[ 0.609577] rtc_cmos 00:02: RTC can wake from S4
[ 0.610046] rtc_cmos 00:02: registered as rtc0
[ 0.610184] rtc_cmos 00:02: setting system clock to 2021-03-08T06:10:20 UTC (1615183820)
[ 0.610198] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.610203] i2c /dev entries driver
[ 0.610240] device-mapper: uevent: version 1.0.3
[ 0.610302] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 0.610318] platform eisa.0: Probing EISA bus 0
[ 0.610319] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.610320] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.610321] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.610321] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.610322] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.610323] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.610324] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.610324] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.610325] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.610326] platform eisa.0: EISA: Detected 0 cards
[ 0.610329] intel_pstate: Intel P-state driver initializing
[ 0.610982] intel_pstate: HWP enabled
[ 0.611043] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.611048] EFI Variables Facility v0.08 2004-May-17
[ 0.616181] intel_pmc_core INT33A1:00: initialized
[ 0.616298] drop_monitor: Initializing network drop monitor service
[ 0.616514] NET: Registered protocol family 10
[ 0.628326] Segment Routing with IPv6
[ 0.628368] NET: Registered protocol family 17
[ 0.628670] Key type dns_resolver registered
[ 0.630572] microcode: sig=0x506e3, pf=0x20, revision=0xe2
[ 0.630994] microcode: Microcode Update Driver: v2.2.
[ 0.631002] IPI shorthand broadcast: enabled
[ 0.631019] sched_clock: Marking stable (630560996, 402465)->(636332321, -5368860)
[ 0.631357] registered taskstats version 1
[ 0.631371] Loading compiled-in X.509 certificates
[ 0.633545] Loaded X.509 cert 'Build time autogenerated kernel key: 9748ba61e308cdfdb04ca03afcaf8e3100542cc8'
[ 0.633610] zswap: loaded using pool lzo/zbud
[ 0.634215] Key type ._fscrypt registered
[ 0.634217] Key type .fscrypt registered
[ 0.634218] Key type fscrypt-provisioning registered
[ 0.634342] Key type trusted registered
[ 0.641806] Key type encrypted registered
[ 0.641812] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.642371] integrity: Loading X.509 certificate: UEFI:db
[ 0.643302] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[ 0.643304] integrity: Loading X.509 certificate: UEFI:db
[ 0.643738] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[ 0.643739] integrity: Loading X.509 certificate: UEFI:db
[ 0.643792] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.643793] integrity: Loading X.509 certificate: UEFI:db
[ 0.643837] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.643838] integrity: Loading X.509 certificate: UEFI:db
[ 0.644266] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.644631] integrity: Loading X.509 certificate: UEFI:MokListRT
[ 0.644677] integrity: Loaded X.509 cert 'SomeOrg: shim: a01ee84e9b37ace407961cc468c5909447878469'
[ 0.644678] integrity: Loading X.509 certificate: UEFI:MokListRT
[ 0.645143] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.646523] ima: Allocated hash algorithm: sha1
[ 0.649664] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.824932] ima: No architecture policies found
[ 0.824957] evm: Initialising EVM extended attributes:
[ 0.824959] evm: security.selinux
[ 0.824960] evm: security.SMACK64
[ 0.824961] evm: security.SMACK64EXEC
[ 0.824962] evm: security.SMACK64TRANSMUTE
[ 0.824963] evm: security.SMACK64MMAP
[ 0.824964] evm: security.apparmor
[ 0.824965] evm: security.ima
[ 0.824966] evm: security.capability
[ 0.824968] evm: HMAC attrs: 0x1
[ 0.828543] PM: Magic number: 13:830:164
[ 0.828951] RAS: Correctable Errors collector initialized.
[ 0.831417] Freeing unused decrypted memory: 2040K
[ 0.832323] Freeing unused kernel image (initmem) memory: 2644K
[ 0.832446] Write protecting the kernel read-only data: 26624k
[ 0.833546] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 0.834166] Freeing unused kernel image (rodata/data gap) memory: 1440K
[ 0.904402] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.904403] x86/mm: Checking user space page tables
[ 0.948616] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.948624] Run /init as init process
[ 0.948625] with arguments:
[ 0.948625] /init
[ 0.948626] splash
[ 0.948627] with environment:
[ 0.948627] HOME=/
[ 0.948627] TERM=linux
[ 0.948628] BOOT_IMAGE=/boot/vmlinuz-5.8.0-44-generic
[ 1.034924] hid: raw HID events driver (C) Jiri Kosina
[ 1.037118] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.037122] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.037662] ahci 0000:00:17.0: version 3.0
[ 1.038192] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[ 1.038260] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.038404] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.038405] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.038406] usb usb1: Product: xHCI Host Controller
[ 1.038407] usb usb1: Manufacturer: Linux 5.8.0-44-generic xhci-hcd
[ 1.038407] usb usb1: SerialNumber: 0000:00:14.0
[ 1.038530] hub 1-0:1.0: USB hub found
[ 1.038549] hub 1-0:1.0: 16 ports detected
[ 1.040221] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.040226] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.040228] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.040268] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 1.040269] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040270] usb usb2: Product: xHCI Host Controller
[ 1.040271] usb usb2: Manufacturer: Linux 5.8.0-44-generic xhci-hcd
[ 1.040271] usb usb2: SerialNumber: 0000:00:14.0
[ 1.040364] hub 2-0:1.0: USB hub found
[ 1.040374] hub 2-0:1.0: 8 ports detected
[ 1.040693] usb: port power management may be unreliable
[ 1.041491] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 1.041496] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[ 1.045247] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 1.045615] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.045774] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.047515] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 1.048199] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 1.048972] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 1.048973] ahci 0000:00:17.0: flags: 64bit ncq sntf pm led clo only pio slum part ems deso sadm sds apst
[ 1.049292] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 1.057590] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 1.057843] cryptd: max_cpu_qlen set to 1000
[ 1.057894] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 1.062416] AVX2 version of gcm_enc/dec engaged.
[ 1.062417] AES CTR mode by8 optimization enabled
[ 1.067895] libphy: r8169: probed
[ 1.068022] r8169 0000:03:00.1 eth0: RTL8411b, d0:17:c2:1f:cb:ef, XID 5c8, IRQ 129
[ 1.068023] r8169 0000:03:00.1 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.070092] pcieport 0000:00:1c.4: AER: Multiple Corrected error received: 0000:00:1c.4
[ 1.070099] pcieport 0000:00:1c.4: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.070102] pcieport 0000:00:1c.4: AER: device [8086:a114] error status/mask=00000100/00002000
[ 1.070104] pcieport 0000:00:1c.4: AER: [ 8] Rollover
[ 1.079155] pcieport 0000:00:1c.4: AER: Multiple Corrected error received: 0000:00:1c.4
[ 1.079163] pcieport 0000:00:1c.4: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.079167] pcieport 0000:00:1c.4: AER: device [8086:a114] error status/mask=00000100/00002000
[ 1.079169] pcieport 0000:00:1c.4: AER: [ 8] Rollover
[ 1.079449] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 1.079454] pcieport 0000:00:1c.4: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.079455] pcieport 0000:00:1c.4: AER: device [8086:a114] error status/mask=00001000/00002000
[ 1.079457] pcieport 0000:00:1c.4: AER: [12] Timeout
[ 1.091530] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 1.095849] pcieport 0000:00:1c.4: AER: Corrected error received: 0000:00:1c.4
[ 1.095910] pcieport 0000:00:1c.4: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.095912] pcieport 0000:00:1c.4: AER: device [8086:a114] error status/mask=00000100/00002000
[ 1.095914] pcieport 0000:00:1c.4: AER: [ 8] Rollover
[ 1.100616] xhci_hcd 0000:04:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[ 1.101560] checking generic (b0000000 1d5000) vs hw (dd000000 1000000)
[ 1.101561] checking generic (b0000000 1d5000) vs hw (b0000000 10000000)
[ 1.101562] fb0: switching to inteldrmfb from EFI VGA
[ 1.101984] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.102102] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.102103] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102105] usb usb3: Product: xHCI Host Controller
[ 1.102126] usb usb3: Manufacturer: Linux 5.8.0-44-generic xhci-hcd
[ 1.102127] usb usb3: SerialNumber: 0000:04:00.0
[ 1.102604] hub 3-0:1.0: USB hub found
[ 1.102649] hub 3-0:1.0: 2 ports detected
[ 1.103641] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 1.103645] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[ 1.103646] xhci_hcd 0000:04:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.103669] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.103683] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 1.103684] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.103684] usb usb4: Product: xHCI Host Controller
[ 1.103685] usb usb4: Manufacturer: Linux 5.8.0-44-generic xhci-hcd
[ 1.103686] usb usb4: SerialNumber: 0000:04:00.0
[ 1.103781] hub 4-0:1.0: USB hub found
[ 1.103825] hub 4-0:1.0: 2 ports detected
[ 1.107290] scsi host0: ahci
[ 1.107450] scsi host1: ahci
[ 1.107554] scsi host2: ahci
[ 1.107718] scsi host3: ahci
[ 1.107804] ata1: SATA max UDMA/133 abar m2048@0xdf433000 port 0xdf433100 irq 126
[ 1.107805] ata2: SATA max UDMA/133 abar m2048@0xdf433000 port 0xdf433180 irq 126
[ 1.107807] ata3: SATA max UDMA/133 abar m2048@0xdf433000 port 0xdf433200 irq 126
[ 1.107808] ata4: SATA max UDMA/133 abar m2048@0xdf433000 port 0xdf433280 irq 126
[ 1.112857] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.116889] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.117225] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[ 1.128825] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 1.129069] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 1.133958] i2c_hid i2c-ELAN1000:00: supply vdd not found, using dummy regulator
[ 1.133967] i2c_hid i2c-ELAN1000:00: supply vddl not found, using dummy regulator
[ 1.147872] i915 0000:00:02.0: [drm] Panel advertises DPCD backlight support, but VBT disagrees. If your backlight controls don't work try booting with i915.enable_dpcd_backlight=1. If your machine needs this, please file a _new_ bug report on drm/i915, see https://gitlab.freedesktop.org/drm/intel/-/wikis/How-to-file-i915-bugs for details.
[ 1.169971] [drm] Initialized i915 1.6.0 20200515 for 0000:00:02.0 on minor 0
[ 1.173466] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 1.177799] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[ 1.177928] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 1.177981] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:12/LNXVIDEO:01/input/input5
[ 1.210230] fbcon: i915drmfb (fb0) is primary device
[ 1.210232] fbcon: Deferring console take-over
[ 1.210236] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 1.376922] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[ 1.428424] ata3: SATA link down (SStatus 4 SControl 300)
[ 1.428451] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.429028] ata1.00: ATA-8: HFS256G39MND-2300A, 20200L00, max UDMA/133
[ 1.429032] ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.430056] ata1.00: configured for UDMA/133
[ 1.430065] ahci 0000:00:17.0: port does not support device sleep
[ 1.430336] scsi 0:0:0:0: Direct-Access ATA HFS256G39MND-230 0L00 PQ: 0 ANSI: 5
[ 1.430658] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.430724] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 1.430742] sd 0:0:0:0: [sda] Write Protect is off
[ 1.430746] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.430783] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.432674] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.435172] ata2.00: ATAPI: HL-DT-ST DVDRAM GUE1N, AS00, max UDMA/133
[ 1.436490] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.436850] ata2.00: configured for UDMA/133
[ 1.437737] ata4.00: ATA-8: HGST HTS721010A9E630, JB0OA3J0, max UDMA/133
[ 1.437741] ata4.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.439156] ata4.00: configured for UDMA/133
[ 1.440874] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GUE1N AS00 PQ: 0 ANSI: 5
[ 1.461131] sda: sda1 sda2 sda3 sda4 sda5
[ 1.462754] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.520741] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.520744] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.531119] usb 1-1: New USB device found, idVendor=1a2c, idProduct=0e24, bcdDevice= 1.10
[ 1.531123] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.531125] usb 1-1: Product: USB Keyboard
[ 1.531127] usb 1-1: Manufacturer: SEM
[ 1.552935] tsc: Refined TSC clocksource calibration: 2591.999 MHz
[ 1.552947] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cb5c6a11, max_idle_ns: 440795249002 ns
[ 1.553043] clocksource: Switched to clocksource tsc
[ 1.569502] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.569715] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.570134] scsi 3:0:0:0: Direct-Access ATA HGST HTS721010A9 A3J0 PQ: 0 ANSI: 5
[ 1.570481] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 1.570548] sd 3:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.570553] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[ 1.570580] sd 3:0:0:0: [sdb] Write Protect is off
[ 1.570584] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.570624] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.660829] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[ 1.674203] sdb: sdb1 sdb2 sdb3
[ 1.675266] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 1.845412] usb 1-4: New USB device found, idVendor=13d3, idProduct=5666, bcdDevice=10.15
[ 1.845416] usb 1-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.845419] usb 1-4: Product: USB2.0 HD UVC WebCam
[ 1.845421] usb 1-4: Manufacturer: Azurewave
[ 1.845423] usb 1-4: SerialNumber: NULL
[ 1.976908] usb 1-6: new full-speed USB device number 4 using xhci_hcd
[ 2.128352] usb 1-6: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 2.128357] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.128359] usb 1-6: Product: USB Receiver
[ 2.128362] usb 1-6: Manufacturer: Logitech
[ 2.256927] usb 1-9: new full-speed USB device number 5 using xhci_hcd
[ 2.407971] usb 1-9: New USB device found, idVendor=8087, idProduct=0a2a, bcdDevice= 0.01
[ 2.407976] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.424356] usbcore: registered new interface driver usbhid
[ 2.424357] usbhid: USB HID core driver
[ 2.426374] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1A2C:0E24.0001/input/input6
[ 2.485370] hid-generic 0003:1A2C:0E24.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:14.0-1/input0
[ 2.485878] input: SEM USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1A2C:0E24.0002/input/input7
[ 2.545294] input: SEM USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1A2C:0E24.0002/input/input8
[ 2.545624] hid-generic 0003:1A2C:0E24.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:14.0-1/input1
[ 2.546151] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:046D:C534.0003/input/input9
[ 2.605345] hid-generic 0003:046D:C534.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-6/input0
[ 2.606037] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C534.0004/input/input10
[ 2.606481] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C534.0004/input/input11
[ 2.665308] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C534.0004/input/input12
[ 2.665824] hid-generic 0003:046D:C534.0004: input,hiddev0,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-6/input1
[ 2.745730] logitech-djreceiver 0003:046D:C534.0003: hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-6/input0
[ 2.914205] logitech-djreceiver 0003:046D:C534.0004: hiddev0,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-6/input1
[ 2.973853] logitech-djreceiver 0003:046D:C534.0004: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 2.974405] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C534.0004/0003:046D:4054.0005/input/input15
[ 2.974794] hid-generic 0003:046D:4054.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-0000:00:14.0-6/input1:2
[ 3.048079] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C534.0004/0003:046D:4054.0005/input/input19
[ 3.048551] logitech-hidpp-device 0003:046D:4054.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:14.0-6/input1:2
[ 3.284890] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.593767] systemd[1]: Inserted module 'autofs4'
[ 3.631395] systemd[1]: systemd 246.6-1ubuntu1.1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.649104] systemd[1]: Detected architecture x86-64.
[ 3.675159] systemd[1]: Set hostname to <andrea-N552VW>.
[ 3.836709] systemd[1]: /lib/systemd/system/dbus.service:12: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.879624] systemd[1]: /lib/systemd/system/docker.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 3.899194] systemd[1]: /lib/systemd/system/plymouth-start.service:17: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.905662] systemd[1]: /lib/systemd/system/strongswan-starter.service:8: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.914265] systemd[1]: /etc/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
[ 3.939605] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.940500] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 3.940943] systemd[1]: Created slice system-modprobe.slice.
[ 3.941150] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.941409] systemd[1]: Created slice User and Session Slice.
[ 3.941459] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.941591] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.941645] systemd[1]: Reached target Remote File Systems.
[ 3.941654] systemd[1]: Reached target Slices.
[ 3.941674] systemd[1]: Reached target Libvirt guests shutdown.
[ 3.941740] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.941811] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.942814] systemd[1]: Listening on Syslog Socket.
[ 3.942891] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.942926] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.943052] systemd[1]: Listening on Journal Audit Socket.
[ 3.943116] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.943187] systemd[1]: Listening on Journal Socket.
[ 3.943280] systemd[1]: Listening on udev Control Socket.
[ 3.943337] systemd[1]: Listening on udev Kernel Socket.
[ 3.944012] systemd[1]: Mounting Huge Pages File System...
[ 3.944882] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.945934] systemd[1]: Mounting Kernel Debug File System...
[ 3.946788] systemd[1]: Mounting Kernel Trace File System...
[ 3.948740] systemd[1]: Starting Journal Service...
[ 3.949752] systemd[1]: Starting Availability of block devices...
[ 3.950816] systemd[1]: Starting Set the console keyboard layout...
[ 3.951824] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.952850] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.952898] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 3.954172] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.954213] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.956142] systemd[1]: Starting Load Kernel Modules...
[ 3.957347] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.958470] systemd[1]: Starting Coldplug All udev Devices...
[ 3.959775] systemd[1]: Starting Uncomplicated firewall...
[ 3.962127] systemd[1]: Mounted Huge Pages File System.
[ 3.962312] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.962461] systemd[1]: Mounted Kernel Debug File System.
[ 3.962603] systemd[1]: Mounted Kernel Trace File System.
[ 3.963233] systemd[1]: Finished Availability of block devices.
[ 3.964010] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.964564] systemd[1]: Finished Uncomplicated firewall.
[ 3.967458] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 3.969354] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.972696] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 3.972731] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 3.973579] systemd[1]: Starting Load/Save Random Seed...
[ 3.973877] lp: driver loaded but no devices found
[ 3.974716] systemd[1]: Starting Create System Users...
[ 3.977756] ppdev: user-space parallel port driver
[ 3.982565] systemd[1]: Finished Load Kernel Modules.
[ 3.983544] systemd[1]: Mounting FUSE Control File System...
[ 3.984848] systemd[1]: Mounting Kernel Configuration File System...
[ 3.986270] systemd[1]: Starting Apply Kernel Variables...
[ 3.989004] systemd[1]: Finished Load/Save Random Seed.
[ 3.989161] systemd[1]: Mounted FUSE Control File System.
[ 3.989260] systemd[1]: Mounted Kernel Configuration File System.
[ 4.004352] systemd[1]: Finished Apply Kernel Variables.
[ 4.007275] systemd[1]: Finished Create System Users.
[ 4.008133] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.019414] systemd[1]: Finished Set the console keyboard layout.
[ 4.023469] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 4.024740] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 4.054501] systemd[1]: Started Journal Service.
[ 4.272632] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input20
[ 4.329360] intel_rapl_common: Found RAPL domain package
[ 4.329361] intel_rapl_common: Found RAPL domain dram
[ 4.329503] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 4.331924] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 4.340970] elan_i2c i2c-ELAN1000:00: supply vcc not found, using dummy regulator
[ 4.387637] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 4.388292] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 4.388734] pstore: Using crash dump compression: deflate
[ 4.388742] pstore: Registered efi as persistent store backend
[ 4.392948] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.394602] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.404627] asus_wmi: ASUS WMI generic driver loaded
[ 4.409038] asus_wmi: Initialization: 0x1
[ 4.409108] asus_wmi: BIOS WMI version: 7.9
[ 4.409207] asus_wmi: SFUN value: 0xa0077
[ 4.409210] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 4.409211] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 4.412050] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input21
[ 4.424839] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 4.424841] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 4.424841] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 4.424841] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 4.424842] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 4.460950] Intel(R) Wireless WiFi driver for Linux
[ 4.492713] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
[ 4.492715] iwlwifi 0000:02:00.0: Found debug configuration: 0
[ 4.492955] iwlwifi 0000:02:00.0: loaded firmware version 29.163394017.0 7265D-29.ucode op_mode iwlmvm
[ 4.492988] iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 4.590789] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[ 4.600956] intel_rapl_common: Found RAPL domain package
[ 4.600957] intel_rapl_common: Found RAPL domain core
[ 4.600958] intel_rapl_common: Found RAPL domain uncore
[ 4.600959] intel_rapl_common: Found RAPL domain dram
[ 4.607325] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.607697] iwlwifi 0000:02:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 4.611029] snd_hda_intel 0000:00:1f.3: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
[ 4.611277] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.624346] iwlwifi 0000:02:00.0: base HW address: 10:02:b5:78:3f:3e
[ 4.648678] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.648680] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.648681] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.648681] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.648682] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.648683] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 4.648683] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 4.663377] elan_i2c i2c-ELAN1000:00: Elan Touchpad: Module ID: 0x0005, Firmware: 0x0004, Sample: 0x000d, IAP: 0x000e
[ 4.663457] input: Elan Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-5/i2c-ELAN1000:00/input/input22
[ 4.685148] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 4.685724] thermal thermal_zone9: failed to read out thermal zone (-61)
[ 4.689704] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4.921779] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 4.921819] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 4.921862] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 4.921901] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 4.921938] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 4.921973] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 5.560165] Bluetooth: Core ver 2.22
[ 5.560176] mc: Linux media interface: v0.10
[ 5.560181] NET: Registered protocol family 31
[ 5.560181] Bluetooth: HCI device and connection manager initialized
[ 5.560184] Bluetooth: HCI socket layer initialized
[ 5.560188] Bluetooth: L2CAP socket layer initialized
[ 5.560190] Bluetooth: SCO socket layer initialized
[ 5.572293] videodev: Linux video capture interface: v2.00
[ 5.697109] usbcore: registered new interface driver btusb
[ 5.711131] uvcvideo: Found UVC 1.00 device USB2.0 HD UVC WebCam (13d3:5666)
[ 5.711884] Bluetooth: hci0: read Intel version: 370810011003110e32
[ 5.711885] Bluetooth: hci0: Intel device is already patched. patch num: 32
[ 5.718899] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input29
[ 5.718975] usbcore: registered new interface driver uvcvideo
[ 5.718976] USB Video Class driver (1.1.1)
[ 6.712881] Adding 6655996k swap on /dev/sdb2. Priority:-2 extents:1 across:6655996k FS
[ 6.986911] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null)
[ 7.207894] audit: type=1400 audit(1615183827.090:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1137 comm="apparmor_parser"
[ 7.217796] audit: type=1400 audit(1615183827.102:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd" pid=1140 comm="apparmor_parser"
[ 7.217805] audit: type=1400 audit(1615183827.102:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd//qemu_bridge_helper" pid=1140 comm="apparmor_parser"
[ 7.223179] audit: type=1400 audit(1615183827.106:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1133 comm="apparmor_parser"
[ 7.223310] audit: type=1400 audit(1615183827.106:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1141 comm="apparmor_parser"
[ 7.223318] audit: type=1400 audit(1615183827.106:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1141 comm="apparmor_parser"
[ 7.223326] audit: type=1400 audit(1615183827.106:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1141 comm="apparmor_parser"
[ 7.224219] audit: type=1400 audit(1615183827.106:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=1138 comm="apparmor_parser"
[ 7.230663] audit: type=1400 audit(1615183827.110:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=1139 comm="apparmor_parser"
[ 7.230740] audit: type=1400 audit(1615183827.114:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1143 comm="apparmor_parser"
[ 7.906677] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.906681] Bluetooth: BNEP filters: protocol multicast
[ 7.906689] Bluetooth: BNEP socket layer initialized
[ 7.948804] NET: Registered protocol family 38
[ 8.204862] Generic FE-GE Realtek PHY r8169-301:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-301:00, irq=IGNORE)
[ 8.352026] aufs 5.x-rcN-20200622
[ 8.396927] r8169 0000:03:00.1 enp3s0f1: Link is Down
[ 8.414063] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 8.500342] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 8.501758] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[ 8.539251] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.540117] virbr0: port 1(virbr0-nic) entered blocking state
[ 8.540119] virbr0: port 1(virbr0-nic) entered disabled state
[ 8.542136] device virbr0-nic entered promiscuous mode
[ 8.940684] virbr0: port 1(virbr0-nic) entered blocking state
[ 8.940686] virbr0: port 1(virbr0-nic) entered listening state
[ 8.980715] virbr0: port 1(virbr0-nic) entered disabled state
[ 11.051316] L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
[ 13.089748] Bluetooth: RFCOMM TTY layer initialized
[ 13.089752] Bluetooth: RFCOMM socket layer initialized
[ 13.089755] Bluetooth: RFCOMM ver 1.11
[ 14.429957] NET: Registered protocol family 24
[ 14.438088] l2tp_core: L2TP core driver, V2.0
[ 14.439830] l2tp_netlink: L2TP netlink interface
[ 14.441662] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 14.490117] Initializing XFRM netlink socket
[ 15.030920] kauditd_printk_skb: 45 callbacks suppressed
[ 15.030921] audit: type=1400 audit(1615183834.914:57): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=2121 comm="apparmor_parser"
[ 15.183854] Bridge firewalling registered
[ 22.219949] logitech-hidpp-device 0003:046D:4054.0005: HID++ 4.5 device connected.
[ 34.761886] audit: type=1400 audit(1615183854.646:58): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/home/andrea/.local/share/akonadi/mysql.conf" pid=2875 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[ 35.234739] wlp2s0: authenticate with a6:91:b1:bd:f4:45
[ 35.242103] wlp2s0: send auth to a6:91:b1:bd:f4:45 (try 1/3)
[ 35.249490] wlp2s0: authenticated
[ 35.252868] wlp2s0: associate with a6:91:b1:bd:f4:45 (try 1/3)
[ 35.254507] wlp2s0: RX AssocResp from a6:91:b1:bd:f4:45 (capab=0x1011 status=0 aid=1)
[ 35.256504] wlp2s0: associated
[ 35.280430] wlp2s0: Limiting TX power to 23 (23 - 0) dBm as advertised by a6:91:b1:bd:f4:45
[ 35.355848] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 36.167948] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[ 37.088703] audit: type=1400 audit(1615183856.970:59): apparmor="DENIED" operation="open" profile="/usr/sbin/cupsd" name="/proc/1259/attr/apparmor/current" pid=1259 comm="cupsd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
No errors visible. Are the bios post messages displayed, or is the internal display always dead once an external monitor is connected on boot?
Yes, Already during the post phase the internal monitor is dead and no message is displayed, the only way to use the internal and external monitor at same time is to disconnected the external monitor before the boot or select Windows OS in the grub menu
It’s a bios bug then, not fixable if no newer bios updates are released. Does the same happen if you connect it to the displayport connector?
I don’t know, there is only a mini-display port I can try to use that, but first I need to buy a mini-display to hdmi cable.
All works well with a new mini-diplayport to hdmi cable, the problem was the hdmi port.
