Hi!
I am trying to use the cusolverDnDgetrf function to use the cuSolver library for LU factorization but I am running into an issue with the devInfo parameter.
The devInfo gets a value of -1 which according to the documentation means that the 1st parameter (excluding handle) is wrong.
The first parameter is matrix_dim but I cannot figure out why this is wrong.
My matrix_dim is an integer with the value 4 which gives a 4x4 matrix
m is a one-dimensional array with allocated size matrix_dimmatrix_dimsizeof(double)
The values of the matrix are:
10.000000 9.990005 9.980020 9.970045
9.990005 10.000000 9.990005 9.980020
9.980020 9.990005 10.000000 9.990005
9.970045 9.980020 9.990005 10.000000
Here is the function where I try to use the cuSolver function:
This is the output i get:
cusolverDnDgetrf failed. Status: 0, devInfo: -1
void lud_cuda(double *m, int matrix_dim, int choice)
int i=0;
dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
double *m_debug = (double*)malloc(matrix_dim*matrix_dim*sizeof(double));
if(choice == 1)
printf("Using library...\n");
cusolverDnHandle_t handle;
cusolverDnCreate(&handle);
int* devIpiv;
cudaMalloc((void**)&devIpiv, matrix_dim * sizeof(int));
int workspace_size;
cusolverDnDgetrf_bufferSize(handle, matrix_dim, matrix_dim, m, matrix_dim, &workspace_size);
double* devWorkspace;
cudaMalloc((void**)&devWorkspace, workspace_size);
int* devInfo;
cudaMalloc((void**)&devInfo, sizeof(int));
cusolverStatus_t status = cusolverDnDgetrf(handle, matrix_dim, matrix_dim, m, matrix_dim, devWorkspace, devIpiv, devInfo);
cudaDeviceSynchronize();
int* hostInfo = (int*)malloc(sizeof(int));
cudaMemcpy(hostInfo, devInfo, sizeof(int), cudaMemcpyDeviceToHost);
if (status != CUSOLVER_STATUS_SUCCESS || *hostInfo != 0) {
fprintf(stderr, "cusolverDnDgetrf failed. Status: %d, devInfo: %d\n", status, *hostInfo);
} else {
printf("cusolverDnDgetrf succeeded\n");
cudaFree(devIpiv);
cudaFree(devWorkspace);
cusolverDnDestroy(handle);
