I would like to make following circuit with gstreamer
// [ ] -> [ multifilesink ]
// [ nvcamerasrc ] -> [ nvjpegenc ] -> [ tee ]
// [ ] -> [ queue ] -> [multipartmux] -> [ tcpserversink]
The aim is to capture jpg pictures from camera during streaming camera onto a web client.
When I make the whole chain, the multifilesink never write file on the disk.
After tests I found that’s the fault comes from the tcpserversink.
When I don’t add it to the pipeline, the multifilesink works.
gst_bin_add_many(GST_BIN (m_pipeline), m_source, m_filter, m_jpegEncoder, m_tee, m_sink, m_streamerQueue, m_multipartMux, m_tcpServerSink, NULL);
if (gst_element_link_many (m_streamerQueue, m_multipartMux, m_tcpServerSink, NULL) != TRUE)
replaced by
gst_bin_add_many(GST_BIN (m_pipeline), m_source, m_filter, m_jpegEncoder, m_tee, m_sink, m_streamerQueue, m_multipartMux, NULL);
if (gst_element_link_many (m_streamerQueue, m_multipartMux, NULL) != TRUE)
Here is the dot output of the result
When I just add the tcpserversink, I got that
and the multifilesink doesn’t write any file like if the pipe is hanged up.
Here is the initialization code of the tcpfilesink
m_tcpServerSink = gst_element_factory_make("tcpserversink", "tcpserversink");
g_object_set(m_tcpServerSink, "host", "localhost", "port", (gint)m_cameraConfiguration->streamPort(), NULL);
Any clue ?
