CentOS 7.6. This hardware works with the nouveau driver. But I need a special hook that the proprietary driver has.
I’ve made some changes and gotten it to this, but X just doesn’t start. The whole log:
# cat /var/log/Xorg.0.log
[ 8414.140] (--) Log file renamed from "/var/log/Xorg.pid-9667.log" to "/var/log/Xorg.0.log"
[ 8414.140]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 8414.140] X Protocol Version 11, Revision 0
[ 8414.140] Build Operating System: 4.18.10-200.fc28.x86_64
[ 8414.140] Current Operating System: Linux cygnus.darkmtter.org 4.19.7-200.fc28.x86_64 #1 SMP Wed Dec 5 22:47:13 UTC 2018 x86_64
[ 8414.140] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19.7-200.fc28.x86_64 root=/dev/mapper/fedora_cygnus-root ro resume=/dev/mapper/fedora_cygnus-swap rd.lvm.lv=fedora_cygnus/root rd.lvm.lv=fedora_cygnus/swap rd.driver.blacklist=nouveau nouveau.modeset=0
[ 8414.140] Build Date: 01 November 2018 04:04:19PM
[ 8414.140] Build ID: xorg-x11-server 1.19.6-10.fc28
[ 8414.140] Current version of pixman: 0.34.0
[ 8414.140] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8414.140] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8414.140] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec 11 14:06:11 2018
[ 8414.141] (==) Using config file: "/etc/X11/xorg.conf"
[ 8414.141] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 8414.141] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8414.141] (==) ServerLayout "Layout0"
[ 8414.141] (**) |-->Screen "Screen0" (0)
[ 8414.141] (**) | |-->Monitor "Monitor0"
[ 8414.141] (**) | |-->Device "Device0"
[ 8414.141] (**) |-->Input Device "Keyboard0"
[ 8414.141] (**) |-->Input Device "Mouse0"
[ 8414.141] (==) Automatically adding devices
[ 8414.141] (==) Automatically enabling devices
[ 8414.141] (==) Automatically adding GPU devices
[ 8414.141] (==) Automatically binding GPU devices
[ 8414.141] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8414.141] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 8414.141] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 8414.141] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 8414.141] (WW) Disabling Keyboard0
[ 8414.141] (WW) Disabling Mouse0
[ 8414.141] (II) Loader magic: 0x825e00
[ 8414.141] (II) Module ABI versions:
[ 8414.141] X.Org ANSI C Emulation: 0.4
[ 8414.141] X.Org Video Driver: 23.0
[ 8414.141] X.Org XInput driver : 24.1
[ 8414.141] X.Org Server Extension : 10.0
[ 8414.142] (++) using VT number 1
[ 8414.142] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 8414.142] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8414.151] (--) PCI:*(0:9:0:0) 10de:1c02:1043:85b9 rev 161, Mem @ 0x90000000/16777216, 0x800000000/268435456, 0x810000000/33554432, I/O @ 0x00007000/128, BIOS @ 0x????????/65536
[ 8414.151] (II) LoadModule: "glx"
[ 8414.151] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 8414.153] (II) Module glx: vendor="X.Org Foundation"
[ 8414.153] compiled for 1.19.6, module version = 1.0.0
[ 8414.153] ABI class: X.Org Server Extension, version 10.0
[ 8414.153] (II) LoadModule: "nvidia"
[ 8414.153] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 8414.153] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 8414.153] compiled for 4.0.2, module version = 1.0.0
[ 8414.153] Module class: X.Org Video Driver
[ 8414.153] (II) NVIDIA dlloader X Driver 410.78 Sat Nov 10 22:15:52 CST 2018
[ 8414.153] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 8414.153] (II) Loading sub module "fb"
[ 8414.153] (II) LoadModule: "fb"
[ 8414.153] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 8414.153] (II) Module fb: vendor="X.Org Foundation"
[ 8414.153] ABI class: X.Org ANSI C Emulation, version 0.4
[ 8414.153] (II) Loading sub module "wfb"
[ 8414.153] (II) LoadModule: "wfb"
[ 8414.153] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 8414.153] (II) Module wfb: vendor="X.Org Foundation"
[ 8414.154] (II) Loading sub module "ramdac"
[ 8414.154] (II) LoadModule: "ramdac"
[ 8414.154] (II) Module "ramdac" already built-in
[ 8414.154] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 8414.154] (==) NVIDIA(0): RGB weight 888
[ 8414.154] (==) NVIDIA(0): Default visual is TrueColor
[ 8414.154] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 8414.154] (**) NVIDIA(0): Enabling 2D acceleration
[ 8414.154] (II) Loading sub module "glxserver_nvidia"
[ 8414.154] (II) LoadModule: "glxserver_nvidia"
[ 8414.154] (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[ 8414.158] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 8414.158] compiled for 4.0.2, module version = 1.0.0
[ 8414.158] Module class: X.Org Server Extension
[ 8414.158] (II) NVIDIA GLX Module 410.78 Sat Nov 10 22:12:55 CST 2018
If it doesn’t start it should give some kind of error.
nvidia-bug-report.log.gz (2.12 MB)
