Problem with installing CUDA on Quadro
Hi all,
I’m having trouble building the sample projects with CUDA. Here’s the error message I get when I’m trying to do make.
make[1]: Entering directory /home/maryam/NVIDIA_CUDA_SDK/common' src/cutil.cpp:46:27: error: builtin_types.h: No such file or directory make[1]: *** [obj/release/cutil.cpp_o] Error 1 make[1]: Leaving directory /home/maryam/NVIDIA_CUDA_SDK/common’
make: *** [lib/libcutil.so] Error 2
This is not a PATH problem. There is no file named “builtin_types.h” in my entire system.
I would appreciate your help.
You need to install the CUDA toolkit. The SDk is just a collection of examples.
I have CUDA toolkit installed !
builtin_types.h is part of the cuda toolkit.
ls -l /usr/local/cuda/include/builtin_types.h
-rw-r–r-- 1 root root 2367 Jan 3 11:11 /usr/local/cuda/include/builtin_types.h
The problem was that the CUDA_INSTALL_PATH wasn’t set right on common.mk, I think that’s a bug for CUDA 1.1. But, now I get the following error when I’m trying to build the projects:
make -C projects/fluidsGL/
make[1]: Entering directory `/home/maryam/NVIDIA_CUDA_SDK/projects/fluidsGL’
/usr/lib/gcc/i586-suse-linux/4.1.2/…/…/…/…/i586-suse-linux/bin/ld: cannot find -lglut
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/linux/release/fluidsGL] Error 1
make[1]: Leaving directory `/home/maryam/NVIDIA_CUDA_SDK/projects/fluidsGL’
make: *** [projects/fluidsGL/Makefile.ph_build] Error 2
Any help?
No one else has reported problems with CUDA_INSTALL_PATH. How do you believe it should have been set?
In your build failure above, you’re missing libGLUT, which ships with the OS.
This is how CUDA_INSTALL_PATH was set in common.mk:
CUDA_INSTALL_PATH ?= /usr/local/cuda (with the question mark ! )
instead of CUDA_INSTALL_PATH := /usr/local/cuda/cuda
I have installed CUDA 1.0 on a different machine with the same OS (SUSE 10.2) that I’m using now, and didn’t have problems. Doesn’t libGLUT come with display driver?
CUDA_INSTALL_PATH is correct in common.mk. If you look at the Makefile, you’ll it has:
ifdef cuda-install
CUDA_INSTALL_PATH := $(cuda-install)
endif
This serves to set CUDA_INSTALL_PATH to /usr/local/cuda only if you accepted the default install location when you installed the toolkit. The ?= serves as a conditional assignment.
libGL comes with the display driver. libGLUT does not.
Thanks, installed the the libGLUT and it’s working fine now.
