Yes, it was wrong, so I deleted it.
I’ve attempted to set up a test case similar to what you describe.
I started with the CUDA sample code called simpleIPC. I created a modified version of it, adding a section enclosed by #ifdef USE_MOD…#endif, which adds an additional allocation on the device, then does a cudaMemcpy with kind = cudaMemcpyDeviceToDevice, between the just-created allocation, and the pointer acquired by the cudaIPC system. I ran it through the profiler both with and without the mod, so that the profiler difference is easier to spot.
The profiler correctly shows a cudaMemcpy device-to-device transfer, as the additional operation in the GPU trace, for the modified process. Here is a full test case, run on CUDA 9.2, Tesla V100, on a Supermicro server, using CentOS 7:
$ cat simpleIPC_mod.cu
* Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
* This sample demonstrates Inter Process Communication
* features new to SDK 4.1 and uses one process per GPU for computation.
* Note: Multiple processes per single device are possible but not recommended.
* In such cases, one should use IPC events for hardware synchronization.
// Includes
#include <stdio.h>
#include <assert.h>
// CUDA runtime includes
#include <cuda_runtime_api.h>
// CUDA utilities and system includes
#include <helper_cuda.h>
int *pArgc = NULL;
char **pArgv = NULL;
// This sample can support a system-wide maximum of eight peer connections.
#define MAX_DEVICES 8
#define PROCESSES_PER_DEVICE 1
#define DATA_BUF_SIZE 4096
#ifdef __linux
#include <unistd.h>
#include <sched.h>
#include <sys/mman.h>
#include <sys/wait.h>
#include <linux/version.h>
typedef struct ipcCUDA_st
int device;
pid_t pid;
cudaIpcEventHandle_t eventHandle;
cudaIpcMemHandle_t memHandle;
} ipcCUDA_t;
typedef struct ipcDevices_st
int count;
int ordinals[MAX_DEVICES + 1];
} ipcDevices_t;
typedef struct ipcBarrier_st
int count;
bool sense;
bool allExit;
} ipcBarrier_t;
ipcBarrier_t *g_barrier = NULL;
bool g_procSense;
int g_processCount;
void procBarrier()
int newCount = __sync_add_and_fetch(&g_barrier->count, 1);
if (newCount == g_processCount)
g_barrier->count = 0;
g_barrier->sense = !g_procSense;
else
while (g_barrier->sense == g_procSense)
if (!g_barrier->allExit)
sched_yield();
else
exit(EXIT_FAILURE);
g_procSense = !g_procSense;
// CUDA Kernel
__global__ void simpleKernel(int *dst, int *src, int num)
// Dummy kernel
int idx = blockIdx.x * blockDim.x + threadIdx.x;
dst[idx] = src[idx] / num;
void getDeviceCount(ipcDevices_t *devices)
// We can't initialize CUDA before fork() so we need to spawn a new process
pid_t pid = fork();
if (0 == pid)
int i;
int count, uvaCount = 0;
printf("\nChecking for multiple GPUs...\n");
checkCudaErrors(cudaGetDeviceCount(&count));
printf("CUDA-capable device count: %i\n", count);
int *uvaOrdinals = (int*) malloc(sizeof(int)*count);
printf("\nSearching for UVA capable devices...\n");
for (i = 0; i < count; i++)
cudaDeviceProp prop;
checkCudaErrors(cudaGetDeviceProperties(&prop, i));
if (prop.unifiedAddressing)
uvaOrdinals[uvaCount] = i;
printf("> GPU%d = \"%15s\" IS capable of UVA\n", i, prop.name);
uvaCount += 1;
if (prop.computeMode != cudaComputeModeDefault)
printf("> GPU device must be in Compute Mode Default to run\n");
printf("> Please use nvidia-smi to change the Compute Mode to Default\n");
exit(EXIT_SUCCESS);
devices->ordinals[0] = uvaOrdinals[0];
if (uvaCount < 2)
devices->count = uvaCount;
exit(EXIT_SUCCESS);
// Check possibility for peer accesses, relevant to our tests
printf("\nChecking GPU(s) for support of peer to peer memory access...\n");
devices->count = 1;
int canAccessPeer_0i, canAccessPeer_i0;
for (i = 1; i < uvaCount; i++)
checkCudaErrors(cudaDeviceCanAccessPeer(&canAccessPeer_0i, uvaOrdinals[0], uvaOrdinals[i]));
checkCudaErrors(cudaDeviceCanAccessPeer(&canAccessPeer_i0, uvaOrdinals[i], uvaOrdinals[0]));
if (canAccessPeer_0i*canAccessPeer_i0 && devices->count <= MAX_DEVICES)
devices->ordinals[devices->count] = uvaOrdinals[i];
printf("> Two-way peer access between GPU%d and GPU%d: YES\n", devices->ordinals[0], devices->ordinals[devices->count]);
devices->count += 1;
if (devices->count > MAX_DEVICES)
printf("\nSkipping other GPUs, as a this sample can support a system-wide maximum of %d peer connections\n", MAX_DEVICES);
free(uvaOrdinals);
exit(EXIT_SUCCESS);
else
int status;
waitpid(pid, &status, 0);
assert(!status);
inline bool IsAppBuiltAs64()
return sizeof(void*) == 8;
void runTestMultiKernel(ipcCUDA_t *s_mem, int index, ipcDevices_t* s_devices)
* a) Process 0 loads a reference buffer into GPU0 memory
* b) Other processes launch a kernel on the GPU0 memory using P2P
* c) Process 0 checks the resulting buffer
// memory buffer in gpu
int *d_ptr;
// reference buffer in host memory (do in all processes for rand() consistency)
int h_refData[DATA_BUF_SIZE];
for (int i = 0; i < DATA_BUF_SIZE; i++)
h_refData[i] = rand();
checkCudaErrors(cudaSetDevice(s_mem[index].device));
if (index == 0)
printf("\nLaunching kernels...\n");
// host memory buffer for checking results
int *h_results = (int*)malloc(sizeof(int)*DATA_BUF_SIZE * s_devices->count * PROCESSES_PER_DEVICE);
cudaEvent_t *event = (cudaEvent_t*)malloc(sizeof(cudaEvent_t) * s_devices->count * PROCESSES_PER_DEVICE);
checkCudaErrors(cudaMalloc((void **) &d_ptr, DATA_BUF_SIZE * g_processCount * sizeof(int)));
checkCudaErrors(cudaIpcGetMemHandle((cudaIpcMemHandle_t *) &s_mem[0].memHandle, (void *) d_ptr));
checkCudaErrors(cudaMemcpy((void *) d_ptr, (void *) h_refData, DATA_BUF_SIZE * sizeof(int), cudaMemcpyHostToDevice));
// b.1: wait until all event handles are created in other processes
procBarrier();
for (int i = 1; i < g_processCount; i++)
checkCudaErrors(cudaIpcOpenEventHandle(&event[i], s_mem[i].eventHandle));
// b.2: wait until all kernels launched and events recorded
procBarrier();
checkCudaErrors(cudaEventSynchronize(event[i]));
// b.3
procBarrier();
checkCudaErrors(cudaMemcpy(h_results, d_ptr + DATA_BUF_SIZE,
DATA_BUF_SIZE * (g_processCount - 1) * sizeof(int), cudaMemcpyDeviceToHost));
checkCudaErrors(cudaFree(d_ptr));
printf("Checking test results...\n");
for (int n = 1; n < g_processCount; n++)
if (h_refData[i]/(n + 1) != h_results[(n-1) * DATA_BUF_SIZE + i])
fprintf(stderr, "Data check error at index %d in process %d!: %i, %i\n",i,
n, h_refData[i], h_results[(n-1) * DATA_BUF_SIZE + i]);
g_barrier->allExit = true;
exit(EXIT_FAILURE);
free(h_results);
free(event);
else
cudaEvent_t event;
checkCudaErrors(cudaEventCreate(&event, cudaEventDisableTiming | cudaEventInterprocess));
checkCudaErrors(cudaIpcGetEventHandle((cudaIpcEventHandle_t *) &s_mem[index].eventHandle, event));
// b.1: wait until proc 0 initializes device memory
procBarrier();
checkCudaErrors(cudaIpcOpenMemHandle((void **) &d_ptr, s_mem[0].memHandle,
cudaIpcMemLazyEnablePeerAccess));
printf("> Process %3d: Run kernel on GPU%d, taking source data from and writing results to process %d, GPU%d...\n",
index, s_mem[index].device, 0, s_mem[0].device);
const dim3 threads(512, 1);
const dim3 blocks(DATA_BUF_SIZE / threads.x, 1);
simpleKernel<<<blocks, threads>>> (d_ptr + index *DATA_BUF_SIZE, d_ptr, index + 1);
checkCudaErrors(cudaEventRecord(event));
#ifdef USE_MOD
int *dp;
cudaStreamQuery(0);
cudaMalloc(&dp, 512*sizeof(int));
cudaMemcpy(dp, d_ptr, 512*sizeof(int), cudaMemcpyDeviceToDevice);
cudaStreamQuery(0);
#endif
// b.2
procBarrier();
checkCudaErrors(cudaIpcCloseMemHandle(d_ptr));
// b.3: wait till all the events are used up by proc g_processCount - 1
procBarrier();
checkCudaErrors(cudaEventDestroy(event));
cudaDeviceReset();
#endif
int main(int argc, char **argv)
pArgc = &argc;
pArgv = argv;
#if CUDART_VERSION >= 4010 && defined(__linux)
if (!IsAppBuiltAs64())
printf("%s is only supported on 64-bit Linux OS and the application must be built as a 64-bit target. Test is being waived.\n", argv[0]);
exit(EXIT_WAIVED);
#if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,18)
printf("%s is only supported with Linux OS kernel version 2.6.18 and higher. Test is being waived.\n", argv[0]);
exit(EXIT_WAIVED);
#endif
ipcDevices_t *s_devices = (ipcDevices_t *) mmap(NULL, sizeof(*s_devices),
PROT_READ | PROT_WRITE, MAP_SHARED | MAP_ANONYMOUS, 0, 0);
assert(MAP_FAILED != s_devices);
getDeviceCount(s_devices);
if (s_devices->count < 1)
printf("One or more (SM 2.0) class GPUs are required for %s.\n", argv[0]);
printf("Waiving test.\n");
exit(EXIT_SUCCESS);
// initialize our process and barrier data
// if there is more than one device, 1 process per device
if (s_devices->count > 1)
g_processCount = PROCESSES_PER_DEVICE * s_devices->count;
else
g_processCount = 2; // two processes per single device
g_barrier = (ipcBarrier_t *) mmap(NULL, sizeof(*g_barrier),
assert(MAP_FAILED != g_barrier);
memset((void *) g_barrier, 0, sizeof(*g_barrier));
// set local barrier sense flag
g_procSense = 0;
// shared memory for CUDA memory an event handlers
ipcCUDA_t *s_mem = (ipcCUDA_t *) mmap(NULL, g_processCount * sizeof(*s_mem),
assert(MAP_FAILED != s_mem);
// initialize shared memory
memset((void *) s_mem, 0, g_processCount * sizeof(*s_mem));
printf("\nSpawning processes and assigning GPUs...\n");
// index = 0,.., g_processCount - 1
int index = 0;
// spawn "g_processCount - 1" additional processes
int pid = fork();
if (!pid)
index = i;
break;
else
s_mem[i].pid = pid;
// distribute UVA capable devices among processes (1 device per PROCESSES_PER_DEVICE processes)
// if there is only one device, have 1 extra process
s_mem[index].device = s_devices->ordinals[ index / PROCESSES_PER_DEVICE ];
else
s_mem[0].device = s_mem[1].device = s_devices->ordinals[ 0 ];
printf("> Process %3d -> GPU%d\n", index, s_mem[index].device);
// launch our test
runTestMultiKernel(s_mem, index, s_devices);
// Cleanup and shutdown
if (index == 0)
// wait for processes to complete
int status;
waitpid(s_mem[i].pid, &status, 0);
assert(WIFEXITED(status));
printf("\nShutting down...\n");
exit(EXIT_SUCCESS);
#else // Using CUDA 4.0 and older or non Linux OS
printf("simpleIPC requires CUDA 4.1 and Linux to build and run, waiving testing\n\n");
exit(EXIT_WAIVED);
#endif
$ nvcc -arch=sm_70 -o simpleIPC simpleIPC_mod.cu -I/usr/local/cuda/samples/common/inc
$ CUDA_VISIBLE_DEVICES="0" nvprof --print-gpu-trace --profile-child-processes ./simpleIPC
==4008== NVPROF is profiling process 4008, command: ./simpleIPC
CUDA-capable device count: 1
> GPU0 = "Tesla V100-PCIE-32GB" IS capable of UVA
==4008== Profiling application: ./simpleIPC
==4008== Profiling result:
No kernels were profiled.
> Process 0 -> GPU0
> Process 1 -> GPU0
==4007== NVPROF is profiling process 4007, command: ./simpleIPC
==4031== NVPROF is profiling process 4031, command: ./simpleIPC
> Process 1: Run kernel on GPU0, taking source data from and writing results to process 0, GPU0...
==4031== Profiling application: ./simpleIPC
Shutting down...
==4031== Profiling result:
Start Duration Grid Size Block Size Regs* SSMem* DSMem* Device Context Stream Name
8.66010s 4.0640us (8 1 1) (512 1 1) 16 0B 0B Tesla V100-PCIE 1 7 simpleKernel(int*, int*, int) [109]
Regs: Number of registers used per CUDA thread. This number includes registers used internally by the CUDA driver and/or tools and can be more than what the compiler shows.
SSMem: Static shared memory allocated per CUDA block.
DSMem: Dynamic shared memory allocated per CUDA block.
==4007== Profiling application: ./simpleIPC
==4007== Profiling result:
Start Duration Grid Size Block Size Regs* SSMem* DSMem* Size Throughput SrcMemType DstMemType Device Context Stream Name
8.66134s 3.2640us - - - - - 16.000KB 4.6749GB/s Pageable Device Tesla V100-PCIE 1 7 [CUDA memcpy HtoD]
8.66235s 3.7120us - - - - - 16.000KB 4.1107GB/s Device Pageable Tesla V100-PCIE 1 7 [CUDA memcpy DtoH]
SrcMemType: The type of source memory accessed by memory operation/copy
DstMemType: The type of destination memory accessed by memory operation/copy
$ nvcc -arch=sm_70 -o simpleIPC simpleIPC_mod.cu -I/usr/local/cuda/samples/common/inc -DUSE_MOD
==4113== NVPROF is profiling process 4113, command: ./simpleIPC
==4113== Profiling application: ./simpleIPC
==4113== Profiling result:
> Process 0 -> GPU0
> Process 1 -> GPU0
==4112== NVPROF is profiling process 4112, command: ./simpleIPC
==4134== NVPROF is profiling process 4134, command: ./simpleIPC
==4134== Profiling application: ./simpleIPC
Shutting down...
==4134== Profiling result:
8.49721s 4.3520us (8 1 1) (512 1 1) 16 0B 0B - - - - Tesla V100-PCIE 1 7 simpleKernel(int*, int*, int) [109]
8.49752s 1.6960us - - - - - 2.0000KB 1.1246GB/s Device Device Tesla V100-PCIE 1 7 [CUDA memcpy DtoD]
==4112== Profiling application: ./simpleIPC
==4112== Profiling result:
8.49710s 3.2960us - - - - - 16.000KB 4.6295GB/s Pageable Device Tesla V100-PCIE 1 7 [CUDA memcpy HtoD]
8.49816s 3.7120us - - - - - 16.000KB 4.1107GB/s Device Pageable Tesla V100-PCIE 1 7 [CUDA memcpy DtoH]
To be clear, this is the only significant addition in the profiler trace as a result of the mod:
That is what I would expect to see (when we are talking about IPC between processes on the same CUDA device), and so I would have to say I’m unable to reproduce your observation with this test case. It seems to work as expected for me. The transfer is a device-to-device transfer.
