I am having a problem where all of the sudden my jetson only boots to shell and I cant run Bootloader, any recommendations? the heat sync is also extremely warm
Hey,
If you are able to type, try update the UEFI NVRAM boot entries using the bcfg command:
bcfg boot dump
bcfg boot add 0 fs0:\EFI\BOOT\BOOTAA64.EFI “Jetson L4T Launcher”
reset
Run each individual, hope it helps 🤙🏾
We first need to determine whether the device is stopping in the UEFI Interactive Shell or in a Linux shell.
Could you provide the following?
- A clear photo of the complete screen after boot, including the firmware/version banner and the shell prompt.
- The exact JetPack/L4T version you installed (or the SD-card image filename), the boot storage being used (microSD or NVMe), and whether this is the NVIDIA developer kit or a custom carrier board.
- Whether the cooling fan spins after power-on.
Please do not add the suggested bcfg boot entry yet. We first need to confirm which filesystem contains the Jetson bootloader file before changing the persistent UEFI boot configuration.
