Problem With localhost file - Jetracer
I’m following a Jetracer video in EDIO (Engineering Design in Omniverse). When opening the Jetracer.usd in localhost, it properly opens the the Jetracer car, however it also includes a very large object that might be a camera. There didn’t appear to be anyway to delete it Any suggestions? How could the localhost be deleted and then reinstalled as a totally fresh localhost?
Just hit Shift + C to hide Cameras. Shift + L hides lights, G hides grid etc.
You should be able to just select the camera and delete it. I don’t see why not. It just means that this file is done at a tiny scale, which I am not sure why.
Thank you!!! I’m a newbee if you guessed.
Chuck
No problem
