Hi all,
I have installed the workstation 12.10 for evaluating openMP of pgfortran. But the maximum available threads given by the compiler is always 1, while other compilers(gfortran and ifort) return the correct value(8). Is there anything wrong with my installation? By the way, my computer’s cpu is Intel i7 930. The OS running on my PC is fedora 17. Thanks!
Below is the simple code to test maximum threads available.
PROGRAM test_parallel_env
USE omp_lib
IMPLICIT NONE
INTEGER(omp_integer_kind)::max_treads ! The max number of threads
max_threads=omp_get_max_threads()
WRITE(*,*)max_threads
END PROGRAM test_parallel_env
CPU INFO
[kepu@kepu-desktop Parallel]$ grep "model name" /proc/cpuinfo
model name : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Test Result
[kepu@kepu-desktop Parallel]$ pgfortran -mp test_parallel_env.f90 -o test_parallel_env.o
[kepu@kepu-desktop Parallel]$ ./test_parallel_env.o
1
