Problem with multiplication vector by array with big size
Hi People, You ok !!
I’m brazillian begginer student in cuda… i need help and hint to a single problem - “multiplication vector by array with big size”.
I am not able to multiply an array by a vector for values greater than 256, my first result (0,0) is incorrect and to other higher values (1024 …) i get a NaN for some elements of the resultant vector.
I post my program and my results. That your see, results to 512 x 512 to line and col of vector and array are:
[b]Executtando GPU kernel…
GPU time: 1103.490967 msecs.
Executando funcao na CPU…
CPU time: 0.462000 msecs.[/b]
Why worst results ocurrs ? What best path to otmization this sinple code
Helpe me, please !
The CUDA Program
[codebox]
//inclue os arquivos principais
#include <stdio.h>
#include <cutil_inline.h>
#include “/usr/local/cuda/include/cuda.h”
#define DEB
//#define DEB_MAT
//#define DEB_SYNC
#define BLOCK_SIZE 16 //numero de threads em um bloco (16,16,1)= 32 Threads/Bloco
#define N_LINES 512 //numero de linhas do vetor/matriz
#define M_COLS 512 //numero de colunas da matriz
#define DATA 2*N_LINES * M_COLS
//#define RAND_MAT() (((int)(rand()/(float)RAND_MAX *10))%5)+1
//#define RAND_MAT() rand()/(float)RAND_MAX
#define RAND_MAT() 1.0
//Variaveis usadas no host
float* h_vectorA; //Vetor A
float* h_matrixB; //Matriz B
float* h_vectorC; //Vetor resultante C
float* h_vectorT; //Vetor de Teste para o calculo de computaSerial()
//Variaveis usadas no device
float* d_vectorA; //Vetor A
float* d_matrixB; //Matriz B
float* d_vectorC; //Vetor resultante C
//prompt para mostrar mensagem
bool noprompt = false;
//funcoes auxiliares declaradas adiante
void cleanup(void);
void randomInitVector(float*);
void randomInitMatrix(float*);
void computaSerial(float*,const float*, const float*);
void printMatrix(float*);
void printVector(float*);
//codigo do device
global void vectorMultArray(const float* A,
            const float* B, float* C)
int row = blockDim.x * blockIdx.x + threadIdx.x;
int col = blockDim.y * blockIdx.y + threadIdx.y;
if( row<N_LINES && col<M_COLS )
  float Cvalue=0.0F;
  C[__umul24(row , M_COLS) + col] = 0.0;
  for (int e = 0; e < M_COLS; ++e)
Cvalue += A[ __umul24(row , M_COLS) + e] * B[ __umul24(col , M_COLS) + e ];
C[__umul24(row , M_COLS) + col] = Cvalue;
// Host code
int main(int argc, char** argv)
printf("Multiplica vetor por Matriz\n");
printf("A(n) x B(m,n) = C(m)\n\n");
size_t sizeVector = N_LINES * sizeof(float);
size_t sizeMatrix = N_LINES * M_COLS * sizeof(float);
size_t sizeVectorResult = M_COLS * sizeof(float);
unsigned int hTimer;
// use command-line specified CUDA device, otherwise use device with highest Gflops/s
if( cutCheckCmdLineFlag(argc, (const char**)argv, "device") )
  cutilDeviceInit(argc, argv);
else
  cudaSetDevice( cutGetMaxGflopsDeviceId() );
cutilCheckError( cutCreateTimer(&hTimer) );
// Aloca o vetor de entrada A(n)
h_vectorA = (float*)malloc(sizeVector);
if (h_vectorA == 0) cleanup();
// Aloca a matriz de entrada B(m,n)
h_matrixB = (float*)malloc(sizeMatrix);
if (h_matrixB == 0) cleanup();
// Aloca o vetor resultante C(m)
h_vectorC = (float*)malloc(sizeVector);
if (h_vectorC == 0) cleanup();
// Aloca o vetor de teste T(m)
h_vectorT = (float*)malloc(sizeVectorResult);
if (h_vectorT == 0) cleanup();
// Initialize input vectors
randomInitVector(h_vectorA);
randomInitMatrix(h_matrixB);
// Exibe o Vetor e a Matriz inicializada
#ifdef DEBMAT
printVector(h_vectorA);
printMatrix(h_matrixB);
#endif
// Alocate o vetor A, matriz B e vetor resultante C na memória do device
cutilSafeCall( cudaMalloc((void**)&d_vectorA, sizeVector) );
cutilSafeCall( cudaMalloc((void**)&d_matrixB, sizeMatrix) );
cutilSafeCall( cudaMalloc((void**)&d_vectorC, sizeVector) );
// Copia o vetores/matriz da memória do host para o device
cutilSafeCall( cudaMemcpy(d_vectorA,
              h_vectorA, sizeVector, cudaMemcpyHostToDevice) );
cutilSafeCall( cudaMemcpy(d_matrixB,
              h_matrixB, sizeMatrix, cudaMemcpyHostToDevice) );
int threadsPorBloco = BLOCK_SIZE;
dim3 block(threadsPorBloco,
       threadsPorBloco,
       1);
//dim3 grid ( (N_LINES + block.x -1 )/block.x,
//    (N_LINES + block.y -1 )/block.y,
//    1);
dim3 grid (N_LINES/block.x, N_LINES/block.y,1);
printf("Executtando GPU kernel...\n");
  cutilSafeCall( cudaThreadSynchronize() );
  cutilCheckError( cutResetTimer(hTimer) );
  cutilCheckError( cutStartTimer(hTimer) );
vectorMultArray<<<grid,block>>>(d_vectorA, d_matrixB, d_vectorC);
cutilCheckMsg(“A execucao da rotina vectorMultArray() falhou\n”);
  cutilCheckError( cutStopTimer(hTimer) );
printf("GPU time: %f msecs.\n", cutGetTimerValue(hTimer));
#ifdef DEBSYNC
#endif
// Copia o resultado da memoria do device para o host
// h_vectorC contém o resultado da memória do host
cutilSafeCall( cudaMemcpy(h_vectorC,
              d_vectorC, sizeVector, cudaMemcpyDeviceToHost) );
//calcula serial
printf("Executando funcao na CPU...\n");
computaSerial(h_vectorT,h_vectorA,h_matrixB);
printf("CPU time: %f msecs.\n", cutGetTimerValue(hTimer));
#ifdef DEB
printf("\n*****Vetor C Resultante do CUDA*****\n");
printVector(h_vectorC);
printf(“\nVetor T Resultante Serial*\n”);
printVector(h_vectorT);
#endif
// Verifica o resultado
int i;
for (i = 0; i < M_COLS; ++i) {
     if (fabs(h_vectorC[i] - h_vectorT[i]) > 1e-5){
    printf("\n** Problemas na linha do vetor: %d **\n",i);
        break;
printf("%s \n", (i == M_COLS) ? "PASSOU" : "FALHOU");
cleanup();
*Função que imprime uma matriz *
void printMatrix(float* m)
printf(" Matriz inicializada para:\n");
for(int i = 0 ; i < M_COLS ; i++)
printf("\n");
for(int j = 0 ; j < N_LINES ; j++)
    printf("%5.2f", m[ i * M_COLS +j ] );
printf("\n");
*Função que imprime um vetor *
void printVector(float* v)
printf(" Vetor inicializado para: \n[");
for(int i = 0; i<N_LINES; i++)
printf("%5.2f ",v[i]);
printf(“]\n”);
*Função que libera a memória do device e do host *
void cleanup(void)
// Libera a memória do device
if (d_vectorA)
    cudaFree(d_vectorA);
if (d_matrixB)
    cudaFree(d_matrixB);
if (d_vectorC)
    cudaFree(d_vectorC);
// Libera a memória do host
if (h_vectorA)
    free(h_vectorA);
if (h_matrixB)
    free(h_matrixB);
if (h_vectorC)
    free(h_vectorC);
cutilSafeCall( cudaThreadExit() );
if (!noprompt) {
    printf("\nPressione ENTER para sair...\n");
    fflush( stdout);
    fflush( stderr);
    getchar();
exit(0);
*Função que gera o conteúdo aleatório do vetor *
void randomInitVector(float* v)
for (int i = 0; i < N_LINES; ++i)
  v[i] = RAND_MAT();
  • Função que gera o conteúdo aleatório da matriz *
  • *(M.elementos + row * M.largura + col) *
void randomInitMatrix(float* mat)
for (int i = 0; i < M_COLS; ++i)
  for(int j = 0; j < N_LINES; ++j)
mat[ i * M_COLS + j ] = RAND_MAT();
  • Função que calcula a multiplica de um vetor pela matriz *
  • faz um processamento serial e retorna em C *
void computaSerial(float* C,const float* A, const float* B)
for (unsigned int i = 0; i < M_COLS; ++i){
double sum = 0.0F;
for (unsigned int j = 0; j < N_LINES; ++j)
double b = B[i * M_COLS + j];
sum += A[j] * b;
  C[i] = (float)sum;
[/codebox]
Results ============================================================
[b]Multiplica vetor por Matriz
[496.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 ]
[512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 512.00 ]
** Problemas na linha do vetor: 0 **
FALHOU
Pressione ENTER para sair…
