problem with my make file
hi all
this is my makefile
SDK_ROOT = /home/bibrak/NVIDIA_GPU_Computing_SDK
CUDA_LIB_PATH = /usr/local/cuda/lib
INLCUDE = -I$(SDK_ROOT)/C/common/inc -I/usr/local/cuda/include
LIBS = -L$(SDK_ROOT)/lib -lcutil
LIBS += -L$(CUDA_LIB_PATH) -lcudart -lcuda
SRC_CU = test.cu
SRC_CXX =
all:
nvcc -run (INLCUDE) (LIBS) (SRC_CU) (SRC_CXX)
when i run the simple template example it has problems
bibrak@bibrak-laptop:~/NVIDIA_GPU_Computing_SDK/C/src/starter$ make
Makefile:14: *** missing separator. Stop.
any solution
thanks
[codebox]
INCLUDE = -I$(SDK_ROOT)/C/common/inc -I/usr/local/cuda/include
LIBS = -L$(SDK_ROOT)/C/lib -lcutil
SRC_CU = test.cu
SRC_CXX =
all:
/usr/local/cuda/bin/nvcc -o test $(INCLUDE) $(LIBS) $(SRC_CU) $(SRC_CXX)
[/codebox]
IMHO, you’ll be better off using the common makefile in the SDK.
Try out the template project in NVIDIA_GPU_Computing_SDK/C/src/template
N.
Lines with commands in make files have to start with tab char, this is your problem (at least first one).
On a side note: people, please do learn to use code tag when composing messages. Chances are much smaller someone will look into your messages if your just paste your code in.
thanks the tab worked
Oops, looks like I forgot to mention that I updated your makefile in my previous post :)
N.
