I am seeing some differences beyond what can be expected from rounding error with an acc code. I have been able to isolate one of the Kernel and to reproduce the problem in a small test code:
program main
implicit none
integer*4 :: N,ke_soil,i,istarts,iends,kso
real*8, allocatable :: zagc(:,:), zagd(:,:), zage(:,:), t_so_new(:,:)
logical, allocatable :: llandmask(:)
N=1E3
ke_soil=4
istarts=1
iends=N
allocate(llandmask(N),zagc(N,0:ke_soil), zagd(N,0:ke_soil), zage(N,0:ke_soil+1))
allocate(t_so_new(N,0:ke_soil))
!init
DO i=istarts, iends
llandmask(i)=.T.
zage(i,ke_soil+1)=290.0*(1.0 + 1.0/(i))
END DO
DO kso=0,ke_soil
DO i=istarts, iends
zage(i,kso)=(1.0 + 1.0/(i+kso))
zagd(i,kso)=290.0*(1.0 + 1.0/(i+kso))
zagc(i,kso)=(1.0 + 1.0/(i+kso))/288.0
END DO
END DO
!$acc region do seq
DO kso = ke_soil,0,-1
!$acc do kernel
DO i = istarts, iends
IF (llandmask(i)) THEN ! land-points only
zage(i,kso) = zagd(i,kso) - zagc(i,kso)*zage(i,kso+1)
! The surface temperature computed by t_so(i,0,nnew)=zage(i,0) is
! presently unused
t_so_new(i,kso) = zage(i,kso)
END IF ! land-points only
END DO
END DO ! soil layers
!$acc end region
DO kso=0,ke_soil
print*, 'kso, mean(t_so_new)', kso, sum(t_so_new(:,kso))/N
END DO
end program main
If I compile with:
-ta=host
I get:
aprun -n 1 ./test_k_neg_loop
kso, mean(t_so_new) 0 291.1523301069119
kso, mean(t_so_new) 1 290.8646212574333
kso, mean(t_so_new) 2 290.7209103217591
kso, mean(t_so_new) 3 290.6252217333774
kso, mean(t_so_new) 4 290.5473285022244
wit -ta=nvidia
aprun -N 1 ./test_k_neg_loop
kso, mean(t_so_new) 0 292.1672628741607
kso, mean(t_so_new) 1 291.8775595150368
kso, mean(t_so_new) 2 291.7328524090394
kso, mean(t_so_new) 3 291.6364771839715
I actually don’t know whether the issue is coming from the negative incrememnt in the k loop or from the array starting at 0.
Thanks for your help,
Xavier
