Tried drivers 510.47.03, 470.94, and 470.86. On reboot the laptop hangs on bootup prior to getting to the login screen. This is the guide that I have been following to install the different drivers. https://linuxconfig.org/how-to-install-the-nvidia-drivers-on-fedora-28-linux.
Another guide/method used was Howto/NVIDIA - RPM Fusion both yield similar results. Any ideas or suggestions to get the Nvidia driver working would be appreciated as hdmi and external monitors do not currently display.
UPDATE: The laptop display is stuck at the boot up page on the flip side the external display works as if everything is normal and am able to login.
I guess your internal display is driven by the amd/intel igpu and the F28 kernel is too old for it.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
F28 has kernel 5.0, for your Intel comet lake gpu you’ll need kernel 5.2 minimum, likely also some recent linux-firmware package. Any specific reason for using (outdated) F28?
