Problem with OpenACC & generic interface
I try to compile this :
MODULE A
IMPLICIT NONE
INTERFACE GG
  MODULE PROCEDURE C
END INTERFACE
CONTAINS
!$acc routine (C) seq
SUBROUTINE C (K)
INTEGER :: K
END SUBROUTINE
END MODULE
!$acc routine (B) seq
SUBROUTINE B
USE A
INTEGER :: I
CALL C (I)
END SUBROUTINE B
But I get the following error :
[ufh62jk@jean-zay4: 3]$ pgf90 -acc=gpu -c truc.F90
NVFORTRAN-S-1000-Call in OpenACC region to procedure 'c' which has no acc routine information (truc.F90: 29)
  0 inform,   0 warnings,   1 severes, 0 fatal for b
The code compile if remove the INTERFACE block.
Is this expected ?
Regards,
Philippe
Hi Philippe,
It’s an ordering issue. If you move “!$acc routine (C) seq” after the definition of the subroutine, it will work. While I’m not 100% sure on this, but I think with the module procedure, “C” isn’t in scope so the compiler can see the forward definition.
I’d recommend not using the routine directive with a name in this case, but rather put “routine” (without a name) in the subroutine itself. For example:
% cat test.f90
MODULE A
IMPLICIT NONE
INTERFACE GG
  MODULE PROCEDURE C
END INTERFACE
CONTAINS
SUBROUTINE C (K)
!$acc routine seq
INTEGER :: K
END SUBROUTINE
END MODULE
SUBROUTINE B
!$acc routine seq
USE A
INTEGER :: I
CALL C (I)
END SUBROUTINE B
% nvfortran -acc -c test.f90
Hope this helps,
Mat
Thank you Mats, I will do that.
Philippe
