I’m fairly new to GPU programming and I’ve just set up CUDA 5.0 SDK on my CentOS 6.2 machine. All of the code samples compile and run without issue. However, I’m trying to compile some code from another scientist written under CUDA 3.x and I’m getting the following error:
g++ -I/usr/local/cuda-5.0/include -I/usr/local/cuda-5.0/include/CL -I/usr/lib64 -I/usr/lib -lOpenCL -c genome_ocl.cpp -o genome_ocl.o
genome_ocl.cpp:11:22: error: shrUtils.h: No such file or directory
genome_ocl.cpp:12:22: error: oclUtils.h: No such file or directory
genome_ocl.cpp: In function ‘void displayGenomeWideInfo_host(bool*, bool*, PlinkGPU_Locus*, PlinkGPU_Params*, int, int, int)’:
genome_ocl.cpp:47: error: ‘oclGetPlatformID’ was not declared in this scope
genome_ocl.cpp:48: error: ‘oclCheckError’ was not declared in this scope
genome_ocl.cpp:59: error: ‘shrLog’ was not declared in this scope
genome_ocl.cpp:96: error: ‘string’ was not declared in this scope
genome_ocl.cpp:96: error: expected ‘;’ before ‘header_path’
genome_ocl.cpp:97: error: ‘header_path’ was not declared in this scope
genome_ocl.cpp:99: error: ‘oclLoadProgSource’ was not declared in this scope
genome_ocl.cpp:104: error: expected ‘;’ before ‘source_path’
genome_ocl.cpp:105: error: ‘source_path’ was not declared in this scope
genome_ocl.cpp:133: error: ‘LOGBOTH’ was not declared in this scope
genome_ocl.cpp:133: error: ‘ERRORMSG’ was not declared in this scope
genome_ocl.cpp:133: error: ‘STDERROR’ was not declared in this scope
genome_ocl.cpp:133: error: ‘shrLogEx’ was not declared in this scope
genome_ocl.cpp:134: error: ‘oclGetFirstDev’ was not declared in this scope
genome_ocl.cpp:134: error: ‘oclLogBuildInfo’ was not declared in this scope
genome_ocl.cpp:135: error: ‘oclLogPtx’ was not declared in this scope
genome_ocl.cpp:142: error: ‘oclCheckErrorEX’ was not declared in this scope
genome_ocl.cpp:168: error: ‘shrRoundUp’ was not declared in this scope
genome_ocl.cpp: In function ‘char* cl_errstring(cl_int)’:
genome_ocl.cpp:250: error: ‘strdup’ was not declared in this scope
make: *** [genome_ocl.o] Error 1
A “locate” command for shrUtils and oclUtils turns up nothing. The NVIDIA pages for OpenCL (OpenCL | NVIDIA Developer) suggest that everything is in the current drivers. I have the 310.32 driver installed and I’m using card 0 for my GPU work.
[tony@Bach GPGPU]$ nvidia-smi
Thu May 2 13:34:03 2013
| NVIDIA-SMI 4.310.32 Driver Version: 310.32 |
| GPU Name | Bus-Id Disp. | Volatile Uncorr. ECC |
| 0 Quadro 600 | 0000:05:00.0 Off | N/A |
| 30% 49C P0 N/A / N/A | 0% 3MB / 1023MB | 0% Default |
| 1 Quadro FX 580 | 0000:04:00.0 N/A | N/A |
| 40% 42C N/A N/A / N/A | 7% 34MB / 511MB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 1 Not Supported |
I know this isn’t the latest driver, but it’s not that far out-of-date. What am I missing? It must be something simple.
