Problem with Output when using CUDA
Hey all!!
I’m trying to see at the screen the result of my kernel. But I just see this answer:
Final Inverse Matrix
1.#Q0 1.#Q0 1.#Q0
1.#Q0 1.#Q0 1.#Q0
1.#Q0 1.#Q0 1.#Q0
Before printing this, I’m copying these matrix from device to host. All the math behind this is on kernel. Anyone knows what´s happening here?
Maybe a problem of output format??
I’m using a C function to generate this output. The code is shown below:
[codebox]float printMatPoint(float *matriz)
int i, j;
float somatorio=0.0;
for ( i = 0 ; i<LINE_TAM_MAX ; i++)
            for ( j = 0 ; j<COLUMN_TAM_MAX ; j++)
                printf( "%01.3f " ,matriz[i * COLUMN_TAM_MAX + j]);
                somatorio += (float)matriz[i * COLUMN_TAM_MAX + j];
            printf( "\n" );
return somatorio;
[/codebox]
OBS: “somatorio” is only a test variable.
Lys Marie.
Hey all!
The matrizx that I was using was invalid variables. When I copied into the GPU, the mathematical operations were performed upon these invalid values, resulting in a matrix result with invalid values.
I’ve fixed it and now is working perfectly.
Cya soon!
Lys Marie.
Hey all!
Cya soon!
Lys Marie.
