Problem with overlapping tee-related inference results in deepstream
- GPU
• DeepStream Version
- 7.0
• TensorRT Version
- 535.129.03
The code below is currently using tee in deepstream in python.
The problem is that pgie and pgie2 use different models, and if you proceed as shown below, the stream to which the tiler is applied normally outputs results using pgie’s model.
In the second output result, there is a problem in that not only the result of pgie2 but also the inference result of pgie is output together.
I would appreciate it if you could let me know what the problem is.
streammux.link(queue1)
queue1.link(streamdemux)
streamdemux.link(tee)
# queue1.link(tee)
tee1_pad = tee.get_request_pad('src_%u')
if not tee1_pad:
    sys.stderr.write("Unable to get request pads\n")
sink_pad_queue2 = queue2.get_static_pad("sink")
tee1_pad.link(sink_pad_queue2)
queue2.link(pgie)
pgie.link(nvvidconv1)
nvvidconv1.link(queue3)
queue3.link(tiler1)
tiler1.link(queue4)
queue4.link(nvosd1)
nvosd1.link(queue5)
queue5.link(sink1)
# streammux.link(queue10)
# queue10.link(tee)
tee2_pad = tee.get_request_pad("src_%u")
if not tee2_pad:
sink_pad_queue6 = queue6.get_static_pad("sink")
tee2_pad.link(sink_pad_queue6)
queue6.link(pgie2)
pgie2.link(nvvidconv2)
nvvidconv2.link(queue7)
queue7.link(nvosd2)
nvosd2.link(queue8)
queue8.link(sink2)
The above approach will cause batchmeta to not be generated correctly.
Please refer to this sample for parallel inference.
