Parameters like color-effect=1, saturation, contrast… are not known in combination with nvarguscamerasrc, although they are documented for nvcamerasrc. I think, it’s my mistake.
Please can you give me an example with the correct syntax?
( I’m using the jetson nano, latest SD version jetson-nano-sd-r32.2.1.zip. )
Thank you,
best regards,
Wilhelm
hello WiSi-Testpilot,
since the nvcamerasrc has already deprecated for the latest l4t release. please working with nvarguscamerasrc instead.
could you please access L4T Multimedia API Reference for the documentation.
thanks
Hi WiSi-Testpilot
The color-effect was not implement in nvarguscamerasrc.
Please check the support parameter by gst-inspect-1.0 nvarguscamerasrc
Ok, thank you very much for the link and the inspect-command.
Best regards,
Wilhelm
