Problem with python library in headless mode
I am having a problem in using the depth camera intel real sense D435i with Nvidia GPU Jetson Nano.
Trying to use the Nano in the headless mode. In this case, I connect the Nano to my computer usb and go the chrome and type xxx.xxx.xx.x:8888 which opens me Jupyter notebook lab from the nano.
To use the camera, intel has a library called pyrealsense2 with all functions and interfaces for the camera. I installed it with problems.
The problem is: I can only access the functions using jupyter lab if I access jupyter lab using the terminal on the nano (using the nano as a separate computer). In this case jupyter is open in localhost:8888
If I try to type [xxx.xxx.xx.x:8888] on the nano itself, I can see the library but not the functions inside, same problem happens if I use the headless mode.
All details about the steps that I followed, and the outputs are listed in this link:
By default display is enabled in HDMI port. Do you have modification to disable it?
And please check if you can launch the camera by following the steps:
Jetson Nano FAQ
Q: I have a USB camera. How can I launch it on Jetson Nano?
