I want to use yolov5 on AGX Xavier, but encountered a problem with PyTorch (no libcurand.so.10). What can I do to fix it without reflashing Jetson (I only have ssh to it, but no physical access)?
When try to import torch (installed torch-1.10.0-cp36-cp36m-linux_aarch64.whl), there is this error:
jetson@jetson:~/Desktop$ python3
Python 3.6.9 (default, Jun 29 2022, 11:45:57)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
File "<stdin>", line 1, in <module>
File "/home/jetson/.local/lib/python3.6/site-packages/torch/__init__.py", line 196, in <module>
_load_global_deps()
File "/home/jetson/.local/lib/python3.6/site-packages/torch/__init__.py", line 149, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
So libcurand.so.10 is not found. And that’s true. It’s not existent in cuda-10.2 directory:
jetson@jetson:/usr/local/cuda-10.2/lib64$ ls
libcudadevrt.a libcupti.so.10.2.75 libnppicc.so.10.2.1.89 libnppif.so.10 libnppist.so libnppitc_static.a
libcudart.so libnppc.so libnppicc_static.a libnppif.so.10.2.1.89 libnppist.so.10 libnpps.so
libcudart.so.10.2 libnppc.so.10 libnppicom.so libnppif_static.a libnppist.so.10.2.1.89 libnpps.so.10
libcudart.so.10.2.89 libnppc.so.10.2.1.89 libnppicom.so.10 libnppig.so libnppist_static.a libnpps.so.10.2.1.89
libcudart_static.a libnppc_static.a libnppicom.so.10.2.1.89 libnppig.so.10 libnppisu.so libnpps_static.a
libcuinj64.so libnppial.so libnppicom_static.a libnppig.so.10.2.1.89 libnppisu.so.10 libnvperf_host.so
libcuinj64.so.10.2 libnppial.so.10 libnppidei.so libnppig_static.a libnppisu.so.10.2.1.89 libnvperf_target.so
libcuinj64.so.10.2.89 libnppial.so.10.2.1.89 libnppidei.so.10 libnppim.so libnppisu_static.a libnvToolsExt.so
libculibos.a libnppial_static.a libnppidei.so.10.2.1.89 libnppim.so.10 libnppitc.so libnvToolsExt.so.1
libcupti.so libnppicc.so libnppidei_static.a libnppim.so.10.2.1.89 libnppitc.so.10 libnvToolsExt.so.1.0.0
libcupti.so.10.2 libnppicc.so.10 libnppif.so libnppim_static.a libnppitc.so.10.2.1.89 stubs
I have JetPack 4.4 installed.
jetson@jetson:~$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t186ref, EABI: aarch64, DATE: Fri Oct 16 19:37:08 UTC 2020
jetson@jetson:~$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.4.1-b50
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.4.1-b50), nvidia-opencv (= 4.4.1-b50), nvidia-cudnn8 (= 4.4.1-b50), nvidia-tensorrt (= 4.4.1-b50), nvidia-visionworks (= 4.4.1-b50), nvidia-container (= 4.4.1-b50), nvidia-vpi (= 4.4.1-b50), nvidia-l4t-jetson-multimedia-api (>> 32.4-0), nvidia-l4t-jetson-multimedia-api (<< 32.5-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.4.1-b50_arm64.deb
Also there is no libcurand-10-2 (or any other libcurand) when checking apt (with and without sudo)
jetson@jetson:~$ sudo apt list --installed | grep libcurand-10-2
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
