I am currently developing applications using QT+ Opencv + TX2。
The compile error shows as below:
/home/michael/Documents/TX2COMPILE/sysroot/lib/aarch64-linux-gnu/librt.so.1: undefined reference to `__close_nocancel@GLIBC_PRIVATE'
/home/michael/Documents/TX2COMPILE/sysroot/usr/local/lib/libopencv_core.so: undefined reference to `logf@GLIBC_2.27'
I have looked at many cases where the version of glibc referenced by GCC is inconsistent with TX2.
TX2 was compiled at version 2.27 of glibc.
Official recommended compiler chain gcc-linaro-7.3-2018.05.tar version of glibc is 2.25.
Are there any other GCC cross-build toolchains or upgraded versions available?
Sure, This problem is caused by different versions of glibc.
This version difference refers to the glibc version referenced by the cross-editing tool and the glibc version used when compiling Opencv.This is independent of the glibc version of the host PC.
L4T 32.6.1 uses version 2.27 of Glibc.gcc-linaro-7.3-2018.05.tar version of glibc is 2.25.
Make them version consistent.There are two ways to solve this problem:
1、You can lower the glibc version on TX2 and recompile Opencv.
2、Upgrade the version of glibc used by the cross-compilation tool chain
In my use case,I copied the path of /lib/aarch64-linux-gnu all files in the TX2 to the cross-compile chain reference library path:…/…/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/lib .
