Problem with REGISTER_TENSORRT_PLUGIN
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
native Ubuntu 18.04
other
I have a problem with build own plugin (ResizeNearest) to tensorRT (tensorrt 5.1.4) -"undefined reference to symbol ‘getPluginRegistry’ ".
When I add line:
REGISTER_TENSORRT_PLUGIN(ResizeNearestPluginCreator);
My output in cross-compile is:
/home/USER/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_PEGASUS_XT/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: CMakeFiles/sample_integrate_dnn.dir/main.cpp.o: undefined reference to symbol 'getPluginRegistry'
/usr/local/driveworks-2.2/targets/aarch64-Linux/lib/libnvinfer.so.5: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
src/dnn/sample_integrate_dnn/CMakeFiles/sample_integrate_dnn.dir/build.make:370: recipe for target 'src/dnn/sample_integrate_dnn/sample_integrate_dnn' failed
make[2]: *** [src/dnn/sample_integrate_dnn/sample_integrate_dnn] Error 1
CMakeFiles/Makefile2:2825: recipe for target 'src/dnn/sample_integrate_dnn/CMakeFiles/sample_integrate_dnn.dir/all' failed
make[1]: *** [src/dnn/sample_integrate_dnn/CMakeFiles/sample_integrate_dnn.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
How is the name of library which has getPluginRegistry method? I found docs for NvInferRuntime.h which has getPluginRegistry ( TensorRT: NvInferRuntime.h File Reference ), but it is not implemented in tensorRT 5.1.4 (Support for older TRT 5.1.4 · Issue #49 · NVIDIA-AI-IOT/CUDA-PointPillars · GitHub)
Or how implement new plugin ResizeNearest in tensorRT 5.1.4 without REGISTER_TENSORRT_PLUGIN?
I try register plugin with example code
// Look up the plugin in the registry
auto creator = getPluginRegistry()->getPluginCreator(pluginName, pluginVersion);
const PluginFieldCollection* pluginFC = creator->getFieldNames();
// Populate the fields parameters for the plugin layer
// PluginFieldCollection *pluginData = parseAndFillFields(pluginFC, layerFields);
// Create the plugin object using the layerName and the plugin meta data
IPluginV2 *pluginObj = creator->createPlugin(layerName, pluginData);
// Add the plugin to the TensorRT network auto layer = network.addPluginV2(&inputs[0], int(inputs.size()), pluginObj);
… (build rest of the network and serialize engine)
// Destroy the plugin object
pluginObj->destroy()
… (free allocated pluginData)
(Developer Guide :: NVIDIA Deep Learning TensorRT Documentation)
but I don’t know where and how is “network” and “input”
Dear @Matthew_Pimot,
May I know if you are stick to DRIVE SW 10 or you can move to latest release i.e DRIVE OS 5.2.6?
Please see Using bin-file after TensorRT optimization if it helps.
I’d rather stay to DRIVE SW 10, becacuse in driveworks-2.2 are drivenet package and others, but if DRIVE OS 5.2.6 is the only solution, that I can upgrade DRIVE AGX to test.
If your application requires to use of DRIVE DNN modules(like Drivenet), you need to stay on DRIVE SW 10.0 release. In that case, please check sample_dnn_plugin sample code to know how to integrate a layer as plugin.
If your application is based on your custom model, we would encourage you to use DRIVE OS 5.2.6 + DW 4.0 as it has new features compared to DRIVE SW 10.0 (like native support for ResizeNearest layer).
Dear @ SivaRamaKrishnaNV,
I check sample_dnn_plugin sample code, but in this sample I don’t saw the registry plugin:
REGISTER_TENSORRT_PLUGIN(...);
or create plugin:
auto creator = getPluginRegistry()->getPluginCreator("ResizeNearest", "001");
const nvinfer1::PluginFieldCollection* pluginFC = creator->getFieldNames();
nvinfer1::IPluginV2 *pluginObj = creator->createPlugin("086_upsample", pluginFC);
If I comment pluginPath in main and project(dnn_fc_layer_plugin C CXX) in CMakeLists.txt and use:
CHECK_DW_ERROR(dwDNN_initializeTensorRTFromFileNew(&m_dnn, tensorRTModel.c_str(), nullptr,
                                                               DW_PROCESSOR_TYPE_GPU, m_sdk));
I have error: Seriallized engine contains plugin, but no plugin factory was provided.
If I want use Yolo without plugin I have error:
getPluginCreator could not find plugin ResizeNearest version 001 namespace
If I want add plugin but I don’t understand how.
Thanks for help!
