I install CUDA 1.1 on WinXP, and compile and run successfully with MS VS 2005.
I noticed that there are some strange information in the “output” window, if the example is executed with debug mode (i.e. use “F5” to run a debug version).
The execution seems sucessful (“Test PASSED” is shown). however, after the execution, in the “output” window of VS 2005 I saw the following line:
“First-chance exception at 0x7c812a5b in asyncAPI.exe: Microsoft C++ exception: cudaError_enum at memory location 0x0012fcb0…”
especially for asyncAPI, lots of such information is shown.
I wonder whether other people meet the same problem. And, why such exception information is generated? is there something wrong?
I had installed CUDA 1.1 SDK and toolkits, but when I execute the .exe file that will show a message:
“Cuda error in file ‘particleSystem.cu’ in line 80: invalid argument”
I found out the code in line 80:
“CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(vbo));”
If I execute some examples that include this kind of code, the error will generate.
Why did I get this error? How do I solve this problem?
Did you ever find out what causes this? I experience the same thing in various SDK samples and in my own code.
I found out that when calling cudaThreadExit() before the application quits the exception is not thrown. This is strange especially because the guide states: “cudaThreadExit() is implicitly called on host thread exit.”
