Hi folks,
I am trying to normalize the result of a cuFFT with the code below. data[i].x represents the real value, data[i].y the imag value of a complex. The problem I have is that the real value (.x) is calculated and stored correctly, but written also into the .y field.
Example:
Let data[i].x = 10, data[i].y = 30 and size = 5 before execution. After execution the both data[i].x == 2 and data[i].y == 2.
If I comment out one of the lines, the other result is calculated correctly and stored at the correct place. What’s going wrong?
Btw, data is of course a pointer to linear device memory, and size the size of the vector.
As far as I know, cufftDoubleComplex is just a typedef for double2. At the nvcc command line I have specified “-arch sm_13” and my card is capable of compute capability 1.3, so using doubles should not be the problem.
__global__ void dev_normalize(cufftDoubleComplex *data, double size)
int i = blockIdx.x * blockDim.x + threadIdx.x;
if (i < size)
data[i].x /= size;
data[i].y /= size;
__host__ void normalize(cufftDoubleComplex *data, double size)
dev_normalize<<<((int)size+255) / 256, 256>>>(data, size);
