Problem with sum of two structs without ripetition
Hi people, the following code does the sum of two structs without ripetition and, for each couple, it does an “if” that, if success, stores the result in a vector:
__device__ void createPI0(QVECT *Gamma, PI_0 *Pi0, unsigned long int N, unsigned long int N2, float M0, float del, int *dimPi0){
//Dichiarazioni variabili locali sul device
        int linIdx, i, z, j, loc, sh, tid;
        float massa;
        QVECT Candidato;
//Dichiarazione variabile condivisa sul device
        __shared__ int Ind;
//Il primo thread del blocco inizializza la variabile shared
        if (threadIdx.x == 0) {
           Ind = *dimPi0;
        __syncthreads(); //Barriera di sincronizzazione threads
//Calcolo del thread ID
        sh=threadIdx.x+blockDim.x*threadIdx.y;
        tid = blockDim.x*blockDim.y*(blockIdx.x + gridDim.x* blockIdx.y) + sh;
//Algoritmo per il calcolo degli indici giusti in base al thread
        if (tid<N2){
                linIdx=N2-tid;
                i=int(N - 0.5 - sqrt(0.25 - 2 * (1 - linIdx)));
                z=(N+N-1-i)*i;
                j=tid - z/2 + 1 + i;
if (i==j){
                        i=i-1;
                        j=N-1;
//Somma di due quadrivettori
                Candidato.x=Gamma[i].x+Gamma[j].x;
                Candidato.y=Gamma[i].y+Gamma[j].y;
                Candidato.z=Gamma[i].z+Gamma[j].z;
                Candidato.Ene=Gamma[i].Ene+Gamma[j].Ene;
//Controllo massa
                massa=(Candidato.Ene*Candidato.Ene)-(Candidato.x*Candidato.x)-(Candidato.y*Candidato.y)-(Candidato.z*Candidato.z);
if(massa>M0-del && massa<M0+del){
                        loc=atomicAdd(&Ind,1);
                        Pi0[loc].x=Candidato.x;
                        Pi0[loc].y=Candidato.y;
                        Pi0[loc].z=Candidato.z;
                        Pi0[loc].Ene=Candidato.Ene;
                        Pi0[loc].g1=i;
                        Pi0[loc].g2=j;
__syncthreads();
        //Il thread 0 di ogni blocco aggiorna la dimensione parziale dei Pi 0
        if(threadIdx.x==0)
                atomicAdd(dimPi0,Ind);
Now the trouble is that even 10000 threads works fine, for more of 10000 threads the results aren’t correct. Each thread manages only a sum, only a couple of element. Thanks for the help!
no solution? :(
