When I run this command in ubuntu 18 jetson nano
$ git reset --hard 7101c2310341ab3f4675fc565f64f0967e135a6a
./configure
I face an issue like it is failed while checking pkg-config.
After that I have tried to install librkafka using sudo-get install librkafka1,it gets installed .
But when I tried to give
./configure
it gives the same error
You will need to provide a way to reproduce this. Your git command requires a repository before it can be run…looks like you’re already set up in some way prior to running the git
command. I know nothing about librkafka
, and don’t see it under any of the usual apt
repositories, so any information on finding what is needed to download that git
repo version would be useful.
