Hi, I got the following messages in the kernel.log and then the Jetson-nano reboot:
[50340.658107] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50340.830655] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50341.434286] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50342.420779] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50343.422119] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50343.807721] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50344.720790] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50345.211573] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50345.798853] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50346.214990] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50346.837219] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50347.390286] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50347.802709] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50348.313585] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50348.787719] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50349.795655] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50349.982673] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50350.210627] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50350.483952] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[50350.700082] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50351.386340] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50352.308664] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50352.509492] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50352.811680] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[50353.776100] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
So I checked the temperature of Jetson-nano with the command of “cat /sys/class/thermal/thermal_zone0/temp” and the values of temperature are as follows:
AO-therm: 68.5
CPU-therm: 65.5
GPU-therm: 62.0
PLL-therm: 61.0
PMIC-Die: 100.0
thermal-fan-est: 63.3
The frequency of CPU is 1479000 Hz.
Everything seems to be ok, but how comes this message?
I’ve never seen this before, what’s the background service you’re running?
are you able moving to the latest release to repo the same failure?
btw, you could enable tegrastats utility to show the statistics, thanks
You can search the key words of “tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000” in this forum, and you can find several topics containing this message.
For example, the following topic includes this message, but this topic is about usb.
I notice that the value of " -2147483647" is equal to -2^31, and this message is printed by the function of “enforce_temp_range” in the linux kernel. But I don’t understand why the temperature can overflow.
we would like to reproduce the issue locally,
could you please share what’s the background services, or, what’s the use-case you’ve running to see these messages,
thanks
Do you set up the environment based on either project? Or the issue is also observed if you flash only L4T release(such as clean Jetpack 4.6). Would need your hep to share steps so that we can follow the steps to replicate the error first and then do investigation.
