Hello.
I have a problem with the Omniverse 3Ds Max connector.
I didn’t install Autodesk’s usd connector.
If I don’t install the Omniverse 3Ds Max connector and just run 3Ds max, 3Ds max will be executed.
However, when I install the Omniverse 3Ds Max connector, 3Ds max does not run. And an error message appears as below.
The problem is the same even if you format the computer.
Please let me know what I should do.
Hello @gudwnzm! Could you please provide us with a copy of your logs found here: C:\Users\<USERNAME>\Documents\Omniverse\<CONNECTORNAME>
It may contain more information for us to help troubleshoot the issue!
