I am experiencing a number of problems with the Jetson Xavier NX Dev Kit. I set the hotspot to auto start and connected it to another board with an 18V (5.5A) adjustable charger. After a few minutes working properly I noticed that the wifi connection was gone and the Xavier was very hot, especially in the wireless network card area which burned if you touched it. After unplugging it and returning to its normal location, the board is still very hot when it is turned on (now with its charger). In addition, the USB ports do not work if you connect anything (a mouse, a keyboard, an IMU…) and it is no longer able to raise the hotspot again.
I can access by ssh and the display connected by hdmi works correctly. Here is the result of lsusb, lspci and trying to activate the hotspot manually. Attached are the results of dmesg and lshw. Thanks a lot.
:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
:~$ lspci
returns nothing
:~$ nmcli connection up Hotspot
Error: Connection activation failed: No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name)).
Is the “wifi” here really related to the issue or not? Is this wifi based on PCIe or USB?
I don’t really think it is wise to tell whether this device is overheating by “feel” it. You should use tegrastats to show the device status instead of “feel”. 65C and 90C could all be “hot” for human…
There is no error log from your dmesg. Did you dump it with usb devices connected in the beginning or you hot plug it later?
Overheating only exists on wifi board per your description?
If tegrastats shows an acceptable temperature range, then it looks more like wifi board issue.
